User:Bertrik Sikken
| Name | Bertrik Sikken |
| Nick | bertrik |
| Tagline | heb ik niet |
- radio stuff, in particular software-defined radio, LoRa networks
- citizen science and open data (particulate matter measurement, noise, water quality)
TinyGS station: https://app.tinygs.com/station/bertrik@1430247931
LilyGo T-Radar
https://developer.acconeer.com/home/a121-docs-software/a121-esp32
Action 32x32 display
- https://github.com/Pupariaa/Bk-Light-AppBypass works to control it
- software for a similar led display: https://github.com/derkalle4/python3-idotmatrix-client
What I want to do/research:
- make it controllable over a network, e.g. pixelflut-to-BLE converter
investigate thread/matter
- check out openthread
git clone https://github.com/openthread/openthread.git cd openthread git submodule update --init --recursive
- Prepare development environment:
scripts/bootstrap
- Build it:
Thread on ESP32:
- on ESP32 C6 https://gist.github.com/gtxaspec/d26198daadfb0a8b0a0edeae2d3fd58f
- https://github.com/espressif/esp-thread-br
- https://github.com/espressif/esp-idf/tree/master/examples/openthread/ot_rcp
action lsc stekker
sipeed maix dock
rfid keyfob
- firmware github:
advanced lidars for bat detection
livox:
cubecell meshtastic motion detector
configure multitech outdoor gateway
esp32 wtf
kakofonie counter
Stuff to figure out:
- can it run on an ESP32?
- make a prototype
hypno toad
wasbeer / kat classifier
Nespresso brew counter
Remote bat box monitor
Idea:
- challenges:
- design
- hardware
KNMI API
WeAct CH55x board
Zigbee device with esp32
Cameratoezicht in Gouda
SolarEdge
Stookalert
Implementatie:
Resources:
With result:
event: state
Use an audiomoth for this.
ESP32 C3
Flexible LED ticker
Washing machine API
TinyML
Bat box busy signal
Super tiny RFID
Specification:
Actually smart boiler
Alternatives:
Receiving gas meters
Interesting leads:
Multi-network wifi manager
Interesting candidates:
Automated bat counting
What I definitely can do:
Showstoppers:
Open work:
Interesting stuff:
- https://thingsix.com/
Interesting stuff in GATT:
- service 0xC760
- 0x23
- length byte
- 0x10 0x04 fixed header
- 0x00 is ...
ribbon tweeter for bat audio
Someone gave me this idea:
3d glasses
A tear-down here:
Interesting documents:
Waterniveaumeter
Idee:
Online bat detector
- inexpensive ep2c5t144 board
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
Indoor radar speed sign
