Gebruiker:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
TPMSIn progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
Its-g5In progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
... meer resultaten
Understand Bluetooth AP
I'm trying to understand how to set up a bluetooth AP on a basic Linux system, such that you can connect to it using an Android phone or tablet.
The idea is that there is some kind of useful application running on the Linux system, and that the "app" on the tablet/phone provides the user interface, connecting to the Linux system using REST.
Possible useful links:
My starting point is:
  • a Yocto based Linux distribution
  • a Linux 4.1 kernel
  • Bluez 5
Understanding the various Linux drivers and tools in the Linux bluetooth stack
  • btusb: the Linux kernel driver module for many USB/bluetooth adapters, 'modprobe'-ing this module also magically takes care of downloading firmware needed
  • hciconfig, low-level configuration utility for manipulating a bluetooth controller. A bit like ifconfig, it can bring the interface up or down, set options, etc.
  • hcitool, yet another utility to perform low-level bluetooth operations, like querying the name of paired devices
  • bluetoothd, the bluetooth daemon
    • /etc/bluetooth/main.conf : supposedly (one of) the configuration files for bluetoothd
    • bluetoothd can be accessed over DBUS apparently, see Bluez docs
  • bluetoothctl, a more high-level configuration utility, basically a command line user interface towards bluetoothd as I understand it.
And some acronyms:
  • NAP: network access protocol
  • PAN: personal area network
  • BNEP: bluetooth network encapsulation protocol
Getting somewhere: ?
mini word clock in dutch
Local date calculation:
Understanding LoRa
Simple Doppler motion sensors
Rust
Investigate the rust language.
ESP32
AVR Arduino sample rate
Example C code
#define BUF_SIZE    16
static void ISR(void)
    static int16_t lowpass = 0;
    static int32_t sum = 0;
    static bool even = false;
    int16_t input, signal, mixed;
    input = ....
    // HPF input signal
    signal = input - lowpass;
    lowpass += signal >> 4;
    // multiply by carrier
    even = !even;
    sum += mixed ;
    sum -= buffer[index];
    buffer[index] = mixed ;
    // output LPF as 8-bit number
    out = sum >> 7;
ADS-B multilateration
This idea is about determining position of aircraft that don't transmit GPS position themselves.
Many commercial aircraft transmit ADS-B/MODE-S signals containing all kinds of interesting information: aircraft id, altitude, flight number, speed, heading and position. This way you can plot the trajectory of aircraft on a map and get an interesting view of the air traffic around. The arrival of cheap software-defined-radios like the rtl-sdr made it possible for everyone to receive these signals.
Typically, small aircraft like single-engine air planes and helicopters do not transmit the position information, only the aircraft id, altitude and sometimes flight number. Websites like flightradar24 receive information about these small aircraft from many different receivers, and can infer the position by multilateration. Mulitlateration means that the position can be calculated from the relative delay that the ADS-B signal arrived at the different receiver stations (the radio signal moves at the speed of light!). The required accurate time synchronisation needed for this can be calculated in a smart way from the ADS-B signals themselves.
As far as I know, there is no open-source implementation of this.
Stuff needed for this to work:
  • receiver stations at diverse locations are needed, so you get a good 'constellation' receiving aircraft signals from many different angles
  • each receiver station should be able to time-stamp the ADS-B signals it receives. It doesn't really matter if it is accurate in an absolute sense, just needs a certain time resolution.
    • so we need a common convention on how/what to time-stamp ADS-B, take something that is present in each message, e.g. the exact instant that the first bit of the ICAO address is transmitted
  • about time resolution: radio signals move at the speed of light; one sample at 2 Mbps sample rate is 0.5 microsecond, representing a distance of 150m.
  • a central server receives all the ADS-B signals from the multiple receiver stations
    • it matches up the same message from different receivers, knows where each receiver is, and performs the multilateration calculation
    • it continually monitors the time offset of each receiver, by comparing timestamps from ADS-B message that DO contain GPS information
    • since rtl-sdr receivers drift like crazy (up to 100 ppm), the server probably also needs to estimate the drift rate of each receiver. At 100ppm, a one second old timestamp could already be off by 100 us, or 30km!
  • some kind of network protocol to get all the ADS-B data from each receiver to the central server
Seems like someone already did this, see https://github.com/mutability in the repos dump1090, mlat-server and mlat-client.
