Gebruiker:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
TPMSIn progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
Its-g5In progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
... meer resultaten
NB-IoT module
Ordered a SIM7020 and a starter kit, see: https://www.hackster.io/voske65/arduino-nb-iot-with-sim7020-and-t-mobile-027f8f
I plan to experiment with this kind of network connectivity for perhaps a bat activity monitor or air quality monitoring.
ESP now intercom
Idea:
Implement code for samenmeten API
https://www.samenmetenaanluchtkwaliteit.nl/dataportaal/api-application-programming-interface
ESP mesh networking
The makers of the ESP8266 provide a software stack to run a 'mesh network' between ESP8266 nodes. As I understand this allows several ESP devices to join together and create a kind of dynamic network.
What is not quite clear is how this is all modelled. For example, do devices have addresses. And if so, what kind? Does this thing run on top of TCP/IP, or does it run on raw wifi frames? Can you designate one particular node as the 'root node' and let it bridge communication with other networks? Can you do transient low-power communication with the mesh network, e.g. wake-up, send a message, go back to sleep?
Links:
STM32 stlink V2
mini word clock in dutch
Simple Doppler motion sensors
AVR Arduino sample rate
Bat call cleaner
Alternative:
ESP8266 as modbus master:
GPS repeater
Plan:
Indoor radar speed sign
