Gebruiker:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
TPMSIn progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
Its-g5In progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
... meer resultaten
TTN gateway info panel
Problem: if you're running a gateway for the-things-network (TTN), you can see packets coming in by following the packet forwarder log file, but it gives very limited and rather cryptic information. For example, you don't see which node sent a message, so you have no idea how many unique nodes are sending data through your gateway.
This idea is about creating a simple info panel that you can run directly on the TTN gateway itself. The plan is to write this in Python. A typical gateway probably already runs some sort of Linux distribution which has the python binaries available or allows them to be installed easily. Using Python also means that you don't need a compiler/Makefile/etc.
Basic operation of this utility:
  • the gateway software is configured to send its data not just to TTN but also to the gateway info panel utility (running on "localhost"), using the poly packet forwarder
  • the utility listens on a specific UDP port, accepting data according to the Semtech v1 protocol.
  • it parses the plain JSON metadata (modulation parameters, like frequency, LoRa mode, SF, BW, etc.)
  • it also parses the payload bytes, part of the payload is not encrypted, so we can extract the message type, device address and sequence number (FCNT).
  • all incoming packets are shown in a table-like view in the console using the ncurses library.
Initially, the utility will just keep the packets in memory, so it just shows things that happened since you last started it. Later, we can decide to store the data, for example in a database.
The information shown can be just the incoming messages in order of arrival, one line per message. Alternatively it could show a kind of node-centric view, one line per device with info only on the latest message from that node.
mini word clock in dutch
Local date calculation:
Understanding LoRa
Android HabAlert app
see HabAlertApp
Inexpensive ultrasonic player
see UltrasonicPlayer
Simple Doppler motion sensors
