Gebruiker:Bertrik Sikken
User info Bertrik Sikken
Name Bertrik Sikken
Nick bertrik
Tagline heb ik niet
 Project Status
FrontDoorDisplayAbandoned
HabAlertAppAbandoned
ISSOAbandoned
IbmPosDisplayAbandoned
Pico TrackersAbandoned
RadarOnAStickAbandoned
WifiLampAbandoned
A4PaperDispenserCompleted
CJMCU-811Completed
CO2MeterHackingCompleted
CrawlSpaceSensorCompleted
DecodingLoraCompleted
DustSensorCompleted
ElectronicLoadCompleted
EspNowSkipCompleted
IntakefancontrollerCompleted
LichtKrantCompleted
LoRaGatewayCompleted
LoraBatBoxCompleted
LoraWanNodeCompleted
MHZ19Completed
MainsFrequencyCompleted
MiniSTM32F103ZECompleted
PowerLightCompleted
RC522HackingCompleted
RevRadioCompleted
STM32Completed
Secure iButtonCompleted
SoilHumiditySensorCompleted
StofAnanasCompleted
StofradarCompleted
TTNHABBridgeCompleted
VINDRIKTNINGCompleted
ZigbeeCoordinatorCompleted
Sensor-data-bridgeCompleted
AntiLostIn progress
AudioMothIn progress
BT785In progress
TPMSIn progress
CubeCellIn progress
EspAudioSensorIn progress
Esp32camIn progress
FMCWRadarIn progress
Its-g5In progress
KaraburanIn progress
LoRa-E5-miniIn progress
LoraWanDustSensorIn progress
MainsFrequency2.0In progress
MeshtasticIn progress
... meer resultaten
Inexpensive CO2 sensor
Use the MH-Z19 sensor module (about E22,-) to measure the CO2 concentration and an ESP8266 (like a WeMos D1 mini board) to push the measurement data over the internet to a MQTT server. Possibly I can use ESPEasy which makes configuration easy (through a web interface), I'd have to add support for this particular sensor -> ESPEasy seems pretty complicated to get changes accepted, has existing bugs that are not addressed, probably better to write my own custom code.
Further Understanding LoRa
Ultimate goal is to create an SDR algorithm to decode LoRa without the need for dedicated LoRa hardware. This could be useful when tracking HABs transmitting LoRa for example. See DecodingLora.
Android HabAlert app
see HabAlertApp
Inexpensive ultrasonic player
Bat netting results can be improved by playing back ultrasonic bat calls near the net. This project idea is about creating an inexpensive ultrasonic player by cleverly combining inexpensive sub-modules available already on the market.
The ultrasonic player consists basically of the following parts:
  1. a device to store the bat calls (in wav-format) and playing them back in a particular sequence from storage, like a laptop, tablet or raspberry pi
  2. a device to convert the digital audio into an analog audio signal, like a USB "sound card"
  3. a device to amplify the analog audio signal
  4. a device to reproduce the analog audio signal into actual ultrasonic audio, i.e. a speaker
  5. a case to put everything together
  6. a power supply
Ultrasonic audio from bats can range to well over 100 kHz. Sampling theory says that to reproduce a bandwidth of B Hz, you need a sampling rate of at least 2*B.
An USB sound card supporting 96 kHz playback would allow ultrasonic audio up to 48 kHz to be reproduced, possibly enough for use in a bat lure. A possible inexpensive candidate is this ES9023 based USB sound card, costs about E22.-
To amplify the audio signal, I'm thinking of this TDA2030 based amplifier board, costs about E1,- The TDA2030 is an analog amplifier block. It takes (a minimum) of 12V and can output up to 14W. The datasheet claims it has a power bandwidth of 10 Hz to 140 kHz.
As a speaker, I'm thinking of this tweeter Vifa/Tymphany XT25SC90-04, costs about E22,-
As a case, I could create a simple box using our laser cutter, with some tie wraps to hold the parts inside the box.
Power supply:
  • the USB audio card uses USB 5V.
  • the amplifier needs 12V
Perhaps we can use a switching power supply to create the 12V from the USB 5V? It would be nice if everything could be fed off the USB 5V. Possible candidate: 5V-to-12V step-up cable, costs about E3,-
