LichtKrant
Project LichtKrant | |
350px | |
Some 3-colour 80x7 pixel moving LED sign | |
Status | Initializing |
Contact | bertrik |
Last Update | 2019-12-15 |
Found this lichtkrant on the revspace free stuff table.
Processor board
It takes 5V as input.
Connector pinout J1
- 1: pin A8 of IC6 (245)
- 2: GND?
- 3: pin A1
- 4: GND
- 5: pin A2
- 6:
- 7: pin A3
- 8:
- 9: pin A4
- 10:
- 11: pin A5
- 12:
- 13: pin A6
- 14:
- 15: pin A7
- 16:
- 17: pin A8
- 18:
- 19: 5V
- 20: connected to the "ethernet" dipswitch
So it basically looks like a 9 bit bus. Levels on the bus are 5V (so can we drive it with an ESP?)
LED board
The LED board contains the actual pixels, organized in 16 modules of 5x7 LEDs. Each LED has a red sub-pixel and a green sub-pixel, so it can do colors: red, green, orang The LED modules have the text GYXM-G2357ASRG on them.
The are already electronics on it, consisting mostly of 595 chips (serial shift registers).
Possibly useful other info:
