Lastcall
Revision as of 01:22, 2 October 2015 by Qguv (talk | contribs) (updated the finished project (MWE))
Project lastcall
Contact User:qguv
Last Update 2015-10-02
Tells you your last chance to get home via public transit. Currently a small website giving leaving/arrival time estimates from Google Maps Directions API, but will soon have a (much) nicer web interface (automatic updating/cycling and so).
~200 lines of Python running in a Docker container, see the Github and Docker pages. Probably should've used Haskell, but the Python library bindings were somewhat nicer (i.e. don't require globbing together URLs and parsing JSON).
Environment and Hardware
lastcall runs as a web service on shell.space.revspace.nl. It is controlled with systemd.
ssh shell.space.revspace.nl
sudo systemctl start/stop/enable/disable lastcall
The systemd unit will pull the newest version from Docker hub (lags 15 or so minutes from Github pushes but builds much faster), so there's no need to upgrade/install on a network-connected server. :-)
