ZX81plus38 simple to build ZX-81 clone
Project ZX81plus38
350px
Most people I showed my ZX-81 clone (ZX81+35) said they liked it, but with such a tiny board and with so many "difficult" surface mount components, they they doubted whether they would be able to build this kit, so I restarted my effort.
Status Initializing
Contact mahjongg
Last Update 2019-09-18
I started analysing my current schematic, to see whether it contains components that are not available in PTH, and unfortunately there are some, for example "unbuffered inverters" (74HCU04) used in the crystal oscillator, is no longer available in DIP. Also some other logic isn't available in DIP, 13MHz crystals are hard to get in PTH versions, and 6.5MHz are not available at all. I decided to switch from 128K flash ROM to 32K OPT ROM's because the latter are available in DIP-28, while for the former I MUST use a PLC-32 socket. I also found cheap 32K x 8 static RAMs, also in DIP-28, which wil be easier to layout for.
I will design it with KiCad unlike te older version which was designed using Ulticap and Ultiboard.
