Karaburan
Project Karaburan | |
Monitoring water quality | |
Contact | bertrik |
Last Update | 2025-05-16 |
engage with PX4 community on getting a feel if this is useful to use and if so, how to get startedfigure out how to duplicate an MQTT streamdon't bother- write python scripts
arduino turbiditydon't botherturbidity-to-mqttmaybe make this ROS moduleHID-to-mqttmaybe make this ROS module- position/velocity listener script: latitude, longitude, altitude, heading/bearing/track/whatever, velocity
- analoog in op de pi:
- 1-wire stuff:
- Figure out the udev/hotplug mess, we probably need this because many of our peripherals use a serial port:
- in how many places can we store the udev renaming logic (config files)
- can we automate this, make it user friendlier, e.g. some kind of "insert device X now" script
Check:
USB HID as analog input
- install openocd
sudo apt install openocd
- watch the kernel logs
sudo dmesg -w
Verify that it works:
- install the evtest package
- run
influxdb
ROS
Investigation:
- Using gpsd:
- install ros-jazzy-desktop
Topics:
- air quality sensors
- ammonia
- NOx
- water chemical analysis
- nitrates
- ammonia
- dissolved oxygen
- sulfide/sulfate
- phosphates?
- salinity (chlorides?)
- water physical analysis
- temperature
- depth?
- boat control
- trajectory -> steering
- camera control
- post-processing
- data presentation
- video/photo stitching
- time lapse view
- map view of properties
- data presentation
- use cases
- minimum viable prototype
- materials
- boat selection
Investigate RTK GPS
- Chipsets
- uBLOX ZED-F9P
- Boards
- UM980 / UM982
- stop gpsd.socket
- run from command line
Validation
Comparison with reference coordinate
On october 4th, we took the RTK GPS to a kernnet reference point at 51.99712236/4.68886324, results below:
Name | Latitude | Longitude | dx (m) | dy (m) | absolute (m) | Remark |
Reference | 51.99712236 | 4.68886324 | - | - | 0 | by definition |
Screenshot 1 | 51.99712217 | 4.68886567 | 0.167 | -0.021 | 0.168 | - |
Screenshot 2 | 51.99712200 | 4.68886533 | 0.143 | -0.040 | 0.149 | - |
Meting 1 | 51.9971220 | 4.6888663 | 0.210 | -0.040 | 0.214 | - |
Meting 2 | 51.9971222 | 4.6888660 | 0.189 | -0.018 | 0.190 | - |
Average | - | - | 0.177 | -0.030 | 0.180 | - |
Air quality sensors
Nitrogen compounds in air
- NOx: 27.3 ug/m3
- NO2: 18.6 ug/m3 (9.9 ppb)
Water physical analysis
Turbidity / clarity
Boat control
- 2.4 GHz working frequency
- 500m range
Interesting links:
remote control
Parts:
Use cases
material:
Reeuwijkse plassen
See
potential applications:
Detect/find pollution source
Implementation
udev handling of serial ports
The udev config file is:
/etc/udev/rules.d/99-usb-serial.rules
# LIDAR serial converter SUBSYSTEM=="tty", ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="ea60", SYMLINK+="ttyLIDAR", MODE="0660", GROUP="dialout" # quectel GPS SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", SYMLINK+="ttyGPS", MODE="0660", GROUP="dialout" # ublox GPS SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", SYMLINK+="ttyGPS", MODE="0660", GROUP="dialout"
An USB-nano also appears to have a USB vendor/product id of 1a86/7523 ("USB2.0-Serial") ... same as the quectel GPS?
reading temperature sensor
Preparation:
sudo adduser <name> dialout
Setting up the hardware:
Setting up the software:
- Install openwire fs
sudo apt install owfs
sudo mkdir /mnt/1wire
- Configure systemd services
- Start the systemd service
- Check the logs
