Karaburan
Project Karaburan | |
Monitoring water quality | |
Contact | bertrik |
Last Update | 2024-10-16 |
- write python scripts
- arduino turbidity
- turbidity-to-mqtt
- HID-to-mqtt
- position/velocity listener script: latitude, longitude, altitude, heading/bearing/track/whatever, velocity
- analoog in op de pi:
- 1-wire stuff:
Check:
USB HID as analog input
- install openocd
sudo apt install openocd
- watch the kernel logs
sudo dmesg -w
Verify that it works:
- install the evtest package
- run
influxdb
Topics:
- air quality sensors
- ammonia
- NOx
- water chemical analysis
- nitrates
- ammonia
- dissolved oxygen
- sulfide/sulfate
- phosphates?
- salinity (chlorides?)
- water physical analysis
- temperature
- depth?
- boat control
- trajectory -> steering
- camera control
- post-processing
- data presentation
- video/photo stitching
- time lapse view
- map view of properties
- data presentation
- use cases
- minimum viable prototype
- materials
- boat selection
Investigate RTK GPS
- Chipsets
- Boards
- UM980 / UM982
- stop gpsd.socket
- run from command line
Validation
Comparison with reference coordinate
On october 4th, we took the RTK GPS to a kernnet reference point at 51.99712236/4.68886324, results below:
Name | Latitude | Longitude | dx (m) | dy (m) | absolute (m) | Remark |
Reference | 51.99712236 | 4.68886324 | - | - | 0 | by definition |
Screenshot 1 | 51.99712217 | 4.68886567 | 0.167 | -0.021 | 0.168 | - |
Screenshot 2 | 51.99712200 | 4.68886533 | 0.143 | -0.040 | 0.149 | - |
Meting 1 | 51.9971220 | 4.6888663 | 0.210 | -0.040 | 0.214 | - |
Meting 2 | 51.9971222 | 4.6888660 | 0.189 | -0.018 | 0.190 | - |
Average | - | - | 0.177 | -0.030 | 0.180 | - |
Air quality sensors
Nitrogen compounds in air
- NOx: 27.3 ug/m3
- NO2: 18.6 ug/m3 (9.9 ppb)
Water physical analysis
Turbidity / clarity
Boat control
- 2.4 GHz working frequency
- 500m range
Interesting links:
remote control
Parts:
Use cases
material:
Reeuwijkse plassen
See
potential applications:
Detect/find pollution source
Implementation
reading temperature sensor
Preparation:
sudo adduser <name> dialout
Setting up the hardware:
Setting up the software:
- Install openwire fs
sudo apt install owfs
sudo mkdir /mnt/1wire
- Configure systemd services
- Start the systemd service
- Check the logs
