DustSensor
Revision as of 05:42, 10 April 2018 by Bertrik Sikken (talk | contribs)
Project Dust Sensor
Last Update 2018-04-10
To get an idea of the levels of fine dust around my house, I ordered a dust sensor module to play around with. In particular, I ordered this one, the Plantower PMS 7003, AliExpress link. It's being advertised as an advanced generation of dust sensor (7th generation), while still reasonably priced (E15,-). It uses a laser to perform the measurement and it contains a small fan to move the air around.
In parallel with the fine dust level measurement, my device also measures basic meteo data using a BME280 module: temperature, relative humidity and air pressure.
Graph
The data produced by this sensor is sent as JSON to a MQTT server. From there it is picked up by two protocol converters: 1) the Telegraf plugin to insert it into my own influx db and 2) a custom written Java application to forward it to the RIVM samenmeten website
Future work
  • make temperature, humidity and pressure work with the samenmeten website. This code on github suggests that temperature, pressure, humidity should be submitted as fields "Temp", "Pres", "Hum" respectively (instead of "T", "P" and "RH"!)
  • delete old out-of-date data from the samenmeten database, at some point I accidentally submitted some values of 2^31 for some properties (happens when BME280 loses I2C connection): connect to the db using some kind of command-line client
  • make it possible to support more than 1 sensor, e.g. also sensors from friends. Like making a distinction between individual sensors using the MQTT topic where the data is published and perhaps keep a table of metadata (with influxdb credentials, sensor location, etc.) at the MQTT listener level
  • play with other kinds of sensors, in particular the SDS011, AliExpress link.
Results
Data sheets can be found:
The module takes 5V to run and communicates using 3.3V levels. I connect it using a NodeMCU.
Connections
NodeMCU PMS7003/BME280 Remark
D3 PMS7003-RST Pulled-up to 3.3V on NodeMCU side, may not be actually needed
D4 PMS7003-SET Pulled-up to 3.3V on NodeMCU side, may not be actually needed
D5 BME280-SCL I2C-SCL
D6 BME280-SDA I2C-SDA,
D7 PMS7003-TX NodeMCU receive, PMS7003 transmit
D8 PMS7003-RX NodeMCU transmit, PMS7003 receive
3.3V BME280-VCC
Libraries used:
  • SoftwareSerial for serial communication with the sensor
  • WiFiClient for WiFi connectivity
  • WiFiManager to present a captive portal and allow selection of an AP to connect to the internet
  • PubSubClient to handle publishing of data over MQTT
  • BME280I2C and wire for interacting with a BME280 for basic meteo data (temperature, humidity, pressure)
Protocol outgoing data
The protocol for measurement data from the module is that data is sent in frames of 32 bytes at 9600 bps. Each frame starts with specific begin marker bytes, then a length byte, then the actual data, and finally a checksum. I use a simple finite state machine to parse the stream and get synchronized to the frames.
Protocol
Value Meaning Remark
0x42 0x4D Begin marker ASCII for characters 'B' and 'M'
0x00 0x1C Length Length of following data
XX YY PM1.0 concentration (ug/m3) CF=1, standard particles
XX YY PM2.5 concentration (ug/m3) CF=1, standard particles
XX YY PM10 concentration (ug/m3) CF=1, standard particles
XX YY PM1.0 concentration (ug/m3) in atmospheric environment
XX YY PM2.5 concentration (ug/m3) in atmospheric environment
XX YY PM10 concentration (ug/m3) in atmospheric environment
XX YY Number of particles >0.3 um in 0.1 liter air
XX YY Number of particles >0.5 um in 0.1 liter air
XX YY Number of particles >1.0 um in 0.1 liter air
XX YY Number of particles >2.5 um in 0.1 liter air
XX YY Number of particles >5.0 um in 0.1 liter air
XX YY Number of particles >10 um in 0.1 liter air
VV Version number ?
EE Error code ?
C1 C2 Check code basically the sum of all bytes up to the check code
Protocol incoming data
Command Protocol
CC Command 0xE1, 0xE2 or 0xE4
HH LL Data Depends on command
References
List of dust sensors:
Dust measurement blog:
Making graphs of dust data
Sensor
  bertrik/pms7003/json {"pms7003":{"pm1_0":2,"pm2_5":3,"pm10":4},"bme280":{"t":21.1,"rh":50,"p":1012.4}}
Telegraf
Things I did:
    • influxdb output plugin
    • mqtt_consumer plugin
      • data_format="json"
      • data_type="integer"
  systemctl restart telegraf
Grafana
  • SELECT field(amb_pm10)
  • GROUP BY
  • ALIAS BY PM10
Regelgeving
Luftdaten.info
It would be nice to get my data also on the luftdaten.info website and on the lufdaten.info map. Basically I would use the same kind of mechanism as used for RIVM: write a Java program to capture the MQTT stream and convert it to their API.
protocol
Parts of the Luftdaten.info upload protocols are described on the luftdaten wiki.
  • data is sent as a HTTP POST to https://api.luftdaten.info/v1/push-sensor-data/ (NOTE: the trailing slash!)
  • the HTTP POST uses headers "X-PIN" and "X-Sensor"
    • header "X-PIN" seems to indicate the type of data (NOTE: API describes it as "X-Pin" not "X-PIN"! Maybe both are accepted?)
      • 1 = SDS011 or PMS7003
      • 3 = BMP180
      • 5 = PPD42NS
      • 7 = DHT22
      • 11 = BME280
    • header "X-Sensor" seems to indicate the unique sensor id, for example "esp8266-9137604"
    • apparently no "Content-Type" header (NOTE: API describes this header, but it's not explicitly sent by the implementations above)
    • "software_version": string containing the software version of the sender, for example "python-dusty 0.0.1"
      • "value_type" (when X-PIN=1): string describing the measurement item type, can be "P1" (PM10 value) or "P2" (PM2.5 value) with dust value in ug/m3 I suppose
      • "value_type" (when X-PIN=7): string describing the measurement item type, can be "temperature", "humidity"
      • "value": field containing the measurement value (NOTE: in string quotes, not as numeric values!)
As far as I understand, other meta-information like latitude/longitude of the sensor is sent by an e-mail registration process. This is linked to your measurements by means of the unique sensor id.
