Meshtastic
| Project Meshtastic | |
| Last Update | 2025-05-09 |
Intro
The page describes the research done to figure out if Meshtastic can be used to transfer citizen science measurement data.
The proposition of what I want to achieve:
- a citizen science data sensor sends measurement data into the meshtastic network
- at some point the data reaches a meshtastic node that is connected to the internet, which forwards it over MQTT
- a central listener process picks up the data from the internet and processes it further (e.g. forward it to sensor.community)
Stuff to research:
- how extensive is the network, see meshnet.nl coverage map
- how reliable is the network:
- Nodes have a wide range of technical configuration, however the majority of nodes appear to use the following:
- LongFast channel with encryption key '1' is used at 869.525 MHz
- Internet-connected nodes in the Netherlands are usually connected over MQTT at mqtt.meshnet.nl
- a fraction of about 1-in-5 nodes appears to be connected to internet
- hop limit of 3, this is the default
- most nodes are in CLIENT mode (this is good)
Interesting info:
- My own node: https://db.meshnet.nl/da639b54.html
- My t1000-e tracker: https://vanheusden.com/meshtastic/map/view.php?who=dc427970
TODO
- create a particulate matter sensor that sends meshtastic
- write a backend/plugin for my sensor-data-bridge
Design
Overall design:
- citizen science nodes send data in meshtastic-compatible format, so packets can be routed accross the meshtastic network
- data is sent from the node typically every 5 minutes
- data is broadcasted inside the network, until it reaches a node with a MQTT backend connection, typically within a maximum of 3 hops.
- data arriving at the MQTT server is picked up by a backend application, which can then process it further
Protocol design:
- Use the common LongFast channel, with the default key, this makes sure that other nodes understand our message and are able to forward it over MQTT
- Follow the the MeshPacket structure, wrap our citizen science playload in a protobuf with specific portnr (PRIVATE_APP = 256)
- Citizen science payload has its own custom encoding, as usual, so it is basically opaque to meshtastic, just a byte array
- A checksum (16-bit/32-bit?) or MAC at the end of the payload allows us to verify that it really is a citizen science data packet after decryption
- Each packet already has a semi-unique packet id. Combined with the node id, we consider this unique, so we can identify duplicates at the backend
Backend:
- The backend application listens on a topic on the de-facto central MQTT server for the netherlands, used by most meshtastic nodes, which is mqtt.meshnet.nl
- Decoding works as follows:
- Decrypt with the pre-shared-key (this always work but might result in garbage)
- Attempt to decode according to the the protobuf portnum+payload (meshtastic 'Data')
- Check the port number
- Check and remove checksum/MAC in the payload
- Process the citizen science data payload
- If all of the steps above check out, consider it to be a valid packet
- Check in a local cache if this is a duplicate packet and if so, ignore it
- process citizen science data payload: there is no such thing as TTN attributes, so any data required for further forwarding need to be kept locally (e.g. login credentials for opensense / sensor.community)
Packet structure
On the LoRa radio level:
[ 16-symbol preamble | lora explicit header | lora payload ]
Within the lora payload:
[ meshtastic 16-byte header | meshtastic private-data protobuf ]
The protobuf is encrypted using key "AQ==" and a nonce derived from data in the 16-byte header.
Within the meshtastic protobuf:
[ portnum | private-data | flag ]
The private-data is not encrypted separately
Within the private-data:
[ citizen-science payload | 4-byte message authentication code ]
With respect to security coding:
- Algorithm is AES-GCM
- The payload is *not* encrypted, but it suffixed by a message authentication code (MAC)
- The MAC is only 32-bit, to keep the length manageable
- The nonce used to calculate the MAC is similar to the earlier used nonce, but with the 'extra nonce' data equal to some application-specific id
Could be something like (python):
cipher = AES.new(key, AES.MODE_GCM, nonce=nonce, mac_len=4) # 4-byte auth tag ciphertext, auth_tag = cipher.encrypt_and_digest(message)
or (ESP32):
mbedtls_gcm_context gcm;
mbedtls_gcm_init(&gcm);
mbedtls_gcm_setkey(&gcm, MBEDTLS_CIPHER_ID_AES, key, 128); // 128-bit AES
mbedtls_gcm_crypt_and_tag(&gcm, MBEDTLS_GCM_ENCRYPT,
sizeof(plaintext), nonce, sizeof(nonce),
NULL, 0, plaintext, ciphertext,
sizeof(auth_tag), auth_tag);
Protocol
Quick links:
- radio parameters, for LongFast
- Frequency: 869.525 MHz
- LongFast = SF11BW250, CR 4/5, 16 symbols preamble, explicit header, CRC on
- sync word = 0x2B ("to be")
- typically about 500 ms of transmission time for a packet of about 40 bytes total
- data structure:
- unencrypted header https://meshtastic.org/docs/overview/mesh-algo/#layer-1-unreliable-zero-hop-messaging
- encrypted protobuf with https://buf.build/meshtastic/protobufs/docs/main:meshtastic#meshtastic.Data
- Over MQTT: Service Envelope, wraps a MeshPacket: https://buf.build/meshtastic/protobufs/docs/main:meshtastic#meshtastic.ServiceEnvelope
- Over MQTT: MeshPacket https://buf.build/meshtastic/protobufs/docs/main:meshtastic#meshtastic.MeshPacket loosely based on the message as sent over-the-air
- Port numbers: https://buf.build/meshtastic/protobufs/docs/main:meshtastic#meshtastic.PortNum
- Meshtastic encryption https://meshtastic.org/docs/overview/encryption/ This is very incomplete! Details need to be reverse-engineered from the code!
I wrote python scripts to interact with the MQTT server and arduino code to run on a LoRa capable ESP32 microcontroller.
See https://github.com/bertrik/mesh-backend
MQTT
In the netherlands, data is typically sent to the 'meshnet.nl' MQTT server, for example
Examples of typical data:
Topics with data on MQTT have the following structure:
msh/REGION/2/e/CHANNELNAME/USERID
Sending messages
Requirements for sending mqtt downlinks:
- the meshtastic node needs to have a channel named "mqtt" (exactly), see https://github.com/meshtastic/firmware/blob/master/src/mqtt/MQTT.cpp#L354
- the meshtastic node has JSON be enabled in its MQTT settings
- -> the meshtastic node listens on topic: "ROOT/2/json/mqtt/+", where ROOT = "msh/gouda" in my case
- -> the mqtt publisher sends to topic: 'msh/gouda/2/json/mqtt/!da639b54' for example
- example payload:
{"from": 3663960916, "type": "sendtext", "payload": "Test"}'
Example data
Examples of data as decoded from MQTT using the meshtastic python service wrapper:
packet {
to: 4294967295
decoded {
portnum: POSITION_APP
rx_time: 1741511999
rx_snr: -18
hop_limit: 2
rx_rssi: -128
hop_start: 3
channel_id: "LongFast"
gateway_id: "!da544e50"
Packet with encrypted data:
packet {
to: 4294967295
channel: 8
rx_time: 1741512321
rx_snr: 5.75
hop_limit: 4
rx_rssi: -83
hop_start: 5
gateway_id: "!da5c87d4"
