Meshtastic
Project Meshtastic
Experiments with Meshtastic
Last Update 2025-03-30
Intro
The page describes the research done to figure out if Meshtastic can be used to transfer citizen science measurement data.
The proposition of what I want to achieve:
  • a citizen science data sensor sends measurement data into the meshtastic network
  • at some point the data reaches a meshtastic node that is connected to the internet, which forwards it over MQTT
  • a central listener process picks up the data from the internet and processes it further (e.g. forward it to sensor.community)
Stuff to research:
  • how extensive is the network, see meshnet.nl coverage map
  • how reliable is the network:
    • Nodes have a wide range of technical configuration, however the majority of nodes appear to use the following:
      • LongFast channel with encryption key '1' is used at 869.525 MHz
      • Internet-connected nodes in the Netherlands are usually connected over MQTT at mqtt.meshnet.nl
      • a fraction of about 1-in-5 nodes appears to be connected to internet
      • hop limit of 3, this is the default
      • most nodes are in CLIENT mode (this is good)
Interesting info:
TODO
  • create a particulate matter sensor that sends meshtastic
  • write a backend/plugin for my sensor-data-bridge
Design
Overall design:
  • citizen science nodes send data in meshtastic-compatible format, so packets can be routed accross the meshtastic network
  • data is sent from the node typically every 5 minutes
  • data is broadcasted inside the network, until it reaches a node with a MQTT backend connection, typically within a maximum of 3 hops.
  • data arriving at the MQTT server is picked up by a backend application, which can then process it further
Protocol design:
  • Use the common LongFast channel, with the default key, this makes sure that other nodes understand our message and are able to forward it over MQTT
  • Follow the the MeshPacket structure, wrap our citizen science playload in a protobuf with specific portnr (PRIVATE_APP = 256)
  • Citizen science payload has its own custom encoding, as usual, so it is basically opaque to meshtastic, just a byte array
  • A checksum (16-bit/32-bit?) or MAC at the end of the payload allows us to verify that it really is a citizen science data packet after decryption
  • Each packet already has a semi-unique packet id, so we can identify duplicates at the backend
Backend:
  • The backend application listens on a topic on the de-facto central MQTT server for the netherlands, used by most meshtastic nodes, which is mqtt.meshnet.nl
  • Decoding works as follows:
    • Decrypt with the pre-shared-key (this always work but might result in garbage)
    • Attempt to decode according to the the protobuf portnum+payload (meshtastic 'Data')
    • Check the port number
    • Check and remove checksum/MAC in the payload
  • If all of the steps above check out, consider it to be a valid packet
  • Check in a local cache if this is a duplicate packet and if so, ignore it
  • process citizen science data payload: there is no such thing as TTN attributes, so any data required for further forwarding need to be kept locally (e.g. login credentials for opensense / sensor.community)
Packet structure
On the radio level:
[ lora preamble | ... | <payload> ] <to be documented>
Within the radio payload:
[ meshtastic 16-byte header | citizen science payload | check ]
                            |<---meshtastic encrypted part--->]
Protocol
Quick links:
I wrote python scripts to interact with the MQTT server and arduino code to run on a LoRa capable ESP32 microcontroller.
See https://github.com/bertrik/mesh-backend
MQTT
In the netherlands, data is typically sent to the 'boreft' MQTT server, for example
Examples of typical data:
 msh/7460-7463/2/stat/!da5857c0 online
 msh/EU_868/NL/2/e/LongFast/!eb66115c �%]�g(=���gx�� H5��Aw=]�gE��H`���������LongFast␦
Topics with data on MQTT have the following structure:
 msh/REGION/2/e/CHANNELNAME/USERID
Sending messages
Requirements for sending mqtt downlinks:
  • the meshtastic node needs to have a channel named "mqtt" (exactly), see https://github.com/meshtastic/firmware/blob/master/src/mqtt/MQTT.cpp#L354
  • the meshtastic node has JSON be enabled in its MQTT settings
  • -> the meshtastic node listens on topic: "ROOT/2/json/mqtt/+", where ROOT = "msh/gouda" in my case
  • -> the mqtt publisher sends to topic: 'msh/gouda/2/json/mqtt/!da639b54' for example
  • example payload:
    {"from": 3663960916, "type": "sendtext", "payload": "Test"}'
Example data
Examples of data as decoded from MQTT using the meshtastic python service wrapper:
packet {
  to: 4294967295
  decoded {
    portnum: POSITION_APP
  rx_time: 1741511999
  rx_snr: -18
  hop_limit: 2
  rx_rssi: -128
  hop_start: 3
channel_id: "LongFast"
gateway_id: "!da544e50"
Packet with encrypted data:
packet {
  to: 4294967295
  channel: 8
  rx_time: 1741512321
  rx_snr: 5.75
  hop_limit: 4
  rx_rssi: -83
  hop_start: 5
gateway_id: "!da5c87d4"
