Meshtastic
| Project Meshtastic | |
| Last Update | 2025-03-09 |
Intro
The plan is to use Meshtastic to transfer citizen science measurement data.
Stuff to figure out:
- network coverage: meshnet map
- do nodes forward packets that do not belong to their "own" network? -> appears to be so!
My node: https://db.meshnet.nl/da639b54.html
Design
Option 1
plans:
- just use the 'default' channel: longfast + default key
- put my data on an unused port number, e.g. 300
pro&con:
- + simple
- + my data is routed
- - there are only 256 (or so) port numbers globally, so cannot really differentiate
- could combat this with a kind of secure checksum
Option 2
plans:
- use my own channel: probably 'longfast' + own key
- use a port number > 256
pro&con:
- + data is separate from other data
- + data *should* be routed (not 100% sure)
- - have to do my own decryption
Protocol
Quick links:
- data structure:
- Service Envelope, wraps a MeshPacket: https://buf.build/meshtastic/protobufs/docs/main:meshtastic#meshtastic.ServiceEnvelope
- MeshPacket https://buf.build/meshtastic/protobufs/docs/main:meshtastic#meshtastic.MeshPacket loosely based on the message as sent over-the-air
- Service Envelope: https://buf.build/meshtastic/protobufs/docs/main:meshtastic#meshtastic.ServiceEnvelope
- Port number: https://buf.build/meshtastic/protobufs/docs/main:meshtastic#meshtastic.PortNum
- Meshtastic encryption https://meshtastic.org/docs/overview/encryption/
MQTT
In the netherlands, data is typically sent to the 'boreft' MQTT server, for example
Examples of typical data:
Example data
Examples of data as decoded from MQTT using the meshtastic python service wrapper:
packet {
to: 4294967295
decoded {
portnum: POSITION_APP
rx_time: 1741511999
rx_snr: -18
hop_limit: 2
rx_rssi: -128
hop_start: 3
channel_id: "LongFast"
gateway_id: "!da544e50"
Packet with encrypted data:
packet {
to: 4294967295
channel: 8
rx_time: 1741512321
rx_snr: 5.75
hop_limit: 4
rx_rssi: -83
hop_start: 5
gateway_id: "!da5c87d4"
packet {
to: 4294967295
channel: 8
encrypted: "t\235\250XV\314\256\211\222\253~\245"\357z\252\314U<VZn\210\031\272\230.5\322\345\272\035\212?f\214"
rx_time: 1741514045
hop_limit: 3
priority: BACKGROUND
hop_start: 3
relay_node: 161
gateway_id: "!ac774aa1"
