LDAP/OpenLDAP configuration
< LDAP
The below configuration is used for LDAP at RevSpace, written for and tested with FreeRADIUS 2.5.13. The paths are relative to the base configuration directory, e.g. /etc/ldap
ldap.conf
# needed for anything using libldap TLS_CACERT /etc/ssl/certs/ca-certificates.crt TLS_CACERTDIR /etc/ssl/certs
slapd.conf
# Schemas. include /etc/ldap/schema/core.schema include /etc/ldap/schema/cosine.schema include /etc/ldap/schema/inetorgperson.schema include /etc/ldap/schema/rfc2307bis.schema include /etc/ldap/schema/openssh-lpk.schema # Server pidfile /run/slapd/slapd.pid include /etc/ldap/slapd/local.conf security tls=1 disallow bind_anon require LDAPv3 bind authc strong loglevel none moduleload deref.la moduleload syncprov.la # Database. database ldif suffix "dc=space,dc=revspace,dc=nl" rootdn "cn=admin,dc=space,dc=revspace,dc=nl" rootpw "{CRYPT}$6$rounds=42000$<EXPUNGED>" directory /var/lib/ldap/data password-hash {CRYPT} password-crypt-salt-format "$6$rounds=42000$%.16s" overlay deref include /etc/ldap/slapd/db.replication.conf include /etc/ldap/slapd/db.acl.conf
slapd/
node.conf
# per-server local node configuration serverid 1 pidfile /run/slapd/slapd.pid TLSCACertificateFile /var/lib/dehydrated/certs/ldap2.space.revspace.nl/fullchain.pem TLSCertificateFile /var/lib/dehydrated/certs/ldap2.space.revspace.nl/cert.pem TLSCertificateKeyFile /var/lib/dehydrated/certs/ldap2.space.revspace.nl/privkey.pem # TLSCipherSuite SECURE256:!AES-128-CBC:!ARCFOUR-128:!CAMELLIA-128-CBC:!3DES-CBC:!CAMELLIA-128-CBC:!NULL
db.replication.conf
overlay syncprov syncrepl rid=1 provider=ldaps://ldap2.space.revspace.nl bindmethod=simple binddn="cn=repl-ldap2,ou=services,dc=space,dc=revspace,dc=nl" credentials="<EXPUNGED>" searchbase="dc=space,dc=revspace,dc=nl" schemachecking=on type=refreshAndPersist retry="60 +" #syncrepl rid=2 # bindmethod=simple # binddn="cn=repl-ldap2,ou=services,dc=space,dc=revspace,dc=nl" # credentials="<EXPUNGED>" # searchbase="dc=space,dc=revspace,dc=nl" # schemachecking=on # type=refreshAndPersist # retry="60 +" mirrormode on
db.acl.conf
# User-changeable attributes access to dn.subtree="ou=people,dc=space,dc=revspace,dc=nl" attrs=sshPublicKey,userPassword,loginShell by self write by group="cn=board,ou=groups,dc=space,dc=revspace,dc=nl" write by dn.exact="cn=sshpubkey,ou=services,dc=space,dc=revspace,dc=nl" write by dn.exact="cn=shelldap-gateway,ou=services,dc=space,dc=revspace,dc=nl" write by dn.exact="cn=ldap-sync-scriptje,ou=services,dc=space,dc=revspace,dc=nl" write by dn.subtree="ou=services,dc=space,dc=revspace,dc=nl" read by * auth # Users access to dn.subtree="ou=people,dc=space,dc=revspace,dc=nl" by self read by group="cn=board,ou=groups,dc=space,dc=revspace,dc=nl" write by dn.exact="cn=shelldap-gateway,ou=services,dc=space,dc=revspace,dc=nl" write by dn.exact="cn=ldap-sync-scriptje,ou=services,dc=space,dc=revspace,dc=nl" write by dn.subtree="ou=services,dc=space,dc=revspace,dc=nl" read by * auth # Groups access to dn.subtree="ou=groups,dc=space,dc=revspace,dc=nl" by group="cn=board,ou=groups,dc=space,dc=revspace,dc=nl" write by dn.subtree="ou=services,dc=space,dc=revspace,dc=nl" read by * read # Fallback access to * by group="cn=board,ou=groups,dc=space,dc=revspace,dc=nl" write by * read
schema/
rfc2307bis.schema
Taken from: https://github.com/jtyr/rfc2307bis/tree/4fb02fcfc5816e62716e34a9e27c506e2bedd9c8
### # Extracted from: http://tools.ietf.org/html/draft-howard-rfc2307bis-02 ### # Builtin #attributeType ( 1.3.6.1.1.1.1.0 NAME 'uidNumber' # DESC 'An integer uniquely identifying a user in an # administrative domain' # EQUALITY integerMatch # ORDERING integerOrderingMatch # SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 # SINGLE-VALUE ) # Builtin #attributeType ( 1.3.6.1.1.1.1.1 NAME 'gidNumber' # DESC 'An integer uniquely identifying a group in an # administrative domain' # EQUALITY integerMatch # ORDERING integerOrderingMatch # SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 # SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.2 NAME 'gecos' DESC 'The GECOS field; the common name' EQUALITY caseIgnoreMatch SUBSTR caseIgnoreSubstringsMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.3 NAME 'homeDirectory' DESC 'The absolute path to the home directory' EQUALITY caseExactIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.4 NAME 'loginShell' DESC 'The path to the login shell' EQUALITY caseExactIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.5 NAME 'shadowLastChange' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.6 NAME 'shadowMin' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.7 NAME 'shadowMax' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.8 NAME 'shadowWarning' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.9 NAME 'shadowInactive' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.10 NAME 'shadowExpire' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.11 NAME 'shadowFlag' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.12 NAME 'memberUid' EQUALITY caseExactMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 ) attributeType ( 1.3.6.1.1.1.1.13 NAME 'memberNisNetgroup' EQUALITY caseExactMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 ) attributeType ( 1.3.6.1.1.1.1.14 NAME 'nisNetgroupTriple' DESC 'Netgroup triple' EQUALITY caseIgnoreMatch SUBSTR caseIgnoreSubstringsMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 ) attributeType ( 1.3.6.1.1.1.1.15 NAME 'ipServicePort' DESC 'Service port number' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.16 NAME 'ipServiceProtocol' DESC 'Service protocol name' EQUALITY caseIgnoreMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 ) attributeType ( 1.3.6.1.1.1.1.17 NAME 'ipProtocolNumber' DESC 'IP protocol number' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.18 NAME 'oncRpcNumber' DESC 'ONC RPC number' EQUALITY integerMatch ORDERING integerOrderingMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.27 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.19 NAME 'ipHostNumber' DESC 'IPv4 addresses as a dotted decimal omitting leading zeros or IPv6 addresses as defined in RFC2373' EQUALITY caseIgnoreIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 ) attributeType ( 1.3.6.1.1.1.1.20 NAME 'ipNetworkNumber' DESC 'IP network omitting leading zeros, eg. 192.168' EQUALITY caseIgnoreIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.21 NAME 'ipNetmaskNumber' DESC 'IP netmask omitting leading zeros, eg. 255.255.255.0' EQUALITY caseIgnoreIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.22 NAME 'macAddress' DESC 'MAC address in maximal, colon separated hex notation, eg. 00:00:92:90:ee:e2' EQUALITY caseIgnoreIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 ) attributeType ( 1.3.6.1.1.1.1.23 NAME 'bootParameter' DESC 'rpc.bootparamd parameter' EQUALITY caseExactIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 ) attributeType ( 1.3.6.1.1.1.1.24 NAME 'bootFile' DESC 'Boot image name' EQUALITY caseExactIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26 ) attributeType ( 1.3.6.1.1.1.1.26 NAME 'nisMapName' DESC 'Name of a generic NIS map' EQUALITY caseIgnoreMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15{64} ) attributeType ( 1.3.6.1.1.1.1.27 NAME 'nisMapEntry' DESC 'A generic NIS entry' EQUALITY caseExactMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15{1024} SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.28 NAME 'nisPublicKey' DESC 'NIS public key' EQUALITY octetStringMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.40 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.29 NAME 'nisSecretKey' DESC 'NIS secret key' EQUALITY octetStringMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.40 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.30 NAME 'nisDomain' DESC 'NIS domain' EQUALITY caseIgnoreIA5Match SYNTAX 1.3.6.1.4.1.1466.115.121.1.26{256} ) attributeType ( 1.3.6.1.1.1.1.31 NAME 'automountMapName' DESC 'automount Map Name' EQUALITY caseExactMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.32 NAME 'automountKey' DESC 'Automount Key value' EQUALITY caseExactMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 SINGLE-VALUE ) attributeType ( 1.3.6.1.1.1.1.33 NAME 'automountInformation' DESC 'Automount information' EQUALITY caseExactMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.15 SINGLE-VALUE ) objectClass ( 1.3.6.1.1.1.2.0 NAME 'posixAccount' SUP top AUXILIARY DESC 'Abstraction of an account with POSIX attributes' MUST ( cn $ uid $ uidNumber $ gidNumber $ homeDirectory ) MAY ( userPassword $ loginShell $ gecos $ description ) ) objectClass ( 1.3.6.1.1.1.2.1 NAME 'shadowAccount' SUP top AUXILIARY DESC 'Additional attributes for shadow passwords' MUST uid MAY ( userPassword $ description $ shadowLastChange $ shadowMin $ shadowMax $ shadowWarning $ shadowInactive $ shadowExpire $ shadowFlag ) ) objectClass ( 1.3.6.1.1.1.2.2 NAME 'posixGroup' SUP top AUXILIARY DESC 'Abstraction of a group of accounts' MUST gidNumber MAY ( userPassword $ memberUid $ description ) ) objectClass ( 1.3.6.1.1.1.2.3 NAME 'ipService' SUP top STRUCTURAL DESC 'Abstraction an Internet Protocol service. Maps an IP port and protocol (such as tcp or udp) to one or more names; the distinguished value of the cn attribute denotes the services canonical name' MUST ( cn $ ipServicePort $ ipServiceProtocol ) MAY description ) objectClass ( 1.3.6.1.1.1.2.4 NAME 'ipProtocol' SUP top STRUCTURAL DESC 'Abstraction of an IP protocol. Maps a protocol number to one or more names. The distinguished value of the cn attribute denotes the protocol canonical name' MUST ( cn $ ipProtocolNumber ) MAY description ) objectClass ( 1.3.6.1.1.1.2.5 NAME 'oncRpc' SUP top STRUCTURAL DESC 'Abstraction of an Open Network Computing (ONC) [RFC1057] Remote Procedure Call (RPC) binding. This class maps an ONC RPC number to a name. The distinguished value of the cn attribute denotes the RPC service canonical name' MUST ( cn $ oncRpcNumber ) MAY description ) objectClass ( 1.3.6.1.1.1.2.6 NAME 'ipHost' SUP top AUXILIARY DESC 'Abstraction of a host, an IP device. The distinguished value of the cn attribute denotes the hosts canonical name. Device SHOULD be used as a structural class' MUST ( cn $ ipHostNumber ) MAY ( userPassword $ l $ description $ manager ) ) objectClass ( 1.3.6.1.1.1.2.7 NAME 'ipNetwork' SUP top STRUCTURAL DESC 'Abstraction of a network. The distinguished value of the cn attribute denotes the network canonical name' MUST ipNetworkNumber MAY ( cn $ ipNetmaskNumber $ l $ description $ manager ) ) objectClass ( 1.3.6.1.1.1.2.8 NAME 'nisNetgroup' SUP top STRUCTURAL DESC 'Abstraction of a netgroup. May refer to other netgroups' MUST cn MAY ( nisNetgroupTriple $ memberNisNetgroup $ description ) ) objectClass ( 1.3.6.1.1.1.2.9 NAME 'nisMap' SUP top STRUCTURAL DESC 'A generic abstraction of a NIS map' MUST nisMapName MAY description ) objectClass ( 1.3.6.1.1.1.2.10 NAME 'nisObject' SUP top STRUCTURAL DESC 'An entry in a NIS map' MUST ( cn $ nisMapEntry $ nisMapName ) ) objectClass ( 1.3.6.1.1.1.2.11 NAME 'ieee802Device' SUP top AUXILIARY DESC 'A device with a MAC address; device SHOULD be used as a structural class' MAY macAddress ) objectClass ( 1.3.6.1.1.1.2.12 NAME 'bootableDevice' SUP top AUXILIARY DESC 'A device with boot parameters; device SHOULD be used as a structural class' MAY ( bootFile $ bootParameter ) ) objectClass ( 1.3.6.1.1.1.2.14 NAME 'nisKeyObject' SUP top AUXILIARY DESC 'An object with a public and secret key' MUST ( cn $ nisPublicKey $ nisSecretKey ) MAY ( uidNumber $ description ) ) objectClass ( 1.3.6.1.1.1.2.15 NAME 'nisDomainObject' SUP top AUXILIARY DESC 'Associates a NIS domain with a naming context' MUST nisDomain ) objectClass ( 1.3.6.1.1.1.2.16 NAME 'automountMap' SUP top STRUCTURAL MUST ( automountMapName ) MAY description ) objectClass ( 1.3.6.1.1.1.2.17 NAME 'automount' SUP top STRUCTURAL DESC 'Automount information' MUST ( automountKey $ automountInformation ) MAY description ) objectClass ( 1.3.6.1.1.1.2.18 NAME 'groupOfMembers' SUP top STRUCTURAL DESC 'A group with members (DNs)' MUST cn MAY ( businessCategory $ seeAlso $ owner $ ou $ o $ description $ member ) )
openssh-lpk.schema
Taken from: https://www.nikhef.nl/pdp/files/packages/mkgroup-sshlpk/openssh-lpk.schema
# # LDAP Public Key Patch schema for use with openssh-ldappubkey # Author: Eric AUGE <eau@phear.org> # # Based on the proposal of : Mark Ruijter # # octetString SYNTAX attributetype ( 1.3.6.1.4.1.24552.500.1.1.1.13 NAME 'sshPublicKey' DESC 'OpenSSH Public key' EQUALITY octetStringMatch SYNTAX 1.3.6.1.4.1.1466.115.121.1.40 ) # printableString SYNTAX yes|no objectclass ( 1.3.6.1.4.1.24552.500.1.1.2.0 NAME 'ldapPublicKey' SUP top AUXILIARY DESC 'OpenSSH LPK objectclass' MUST uid MAY sshPublicKey )
skel/
README
LDIF files to import in case the complete LDAP data goes poof. Use like: for x in $(pwd)/*.ldif; do su openldap -s /bin/sh -c "ldapadd -Q -Y EXTERNAL -H ldapi:/// -W -f $x" done After that programs like shelldap should work again.
00-root.ldif
dn: dc=space,dc=revspace,dc=nl objectClass: top objectClass: dcObject objectClass: organization o: RevSpace
01-unit-services.ldif
dn: ou=services,dc=space,dc=revspace,dc=nl objectClass: top objectClass: organizationalUnit ou: services
01-unit-groups.ldif
dn: ou=groups,dc=space,dc=revspace,dc=nl objectClass: top objectClass: organizationalUnit ou: groups
01-unit-people.ldif
dn: ou=people,dc=space,dc=revspace,dc=nl objectClass: top objectClass: organizationalUnit ou: people
