Spacenet/mobileconfig
< Spacenet
http://revspace.nl/s/spacenet.mobileconfig
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>PayloadContent</key> <array> <dict> <key>AutoJoin</key> <true/> <key>EAPClientConfiguration</key> <dict> <key>AcceptEAPTypes</key> <array> <integer>21</integer> </array> <key>PayloadCertificateAnchorUUID</key> <array> <string>7060659C-7F19-4F0C-B292-505D8A41E9A9</string> </array> <key>TTLSInnerAuthentication</key> <string>PAP</string> <key>OuterIdentity</key> <string>anonymous@revspace.nl</string> </dict> <key>EncryptionType</key> <string>WPA</string> <key>HIDDEN_NETWORK</key> <false/> <key>IsHotspot</key> <false/> <key>PayloadDescription</key> <string>Configures wireless connectivity settings.</string> <key>PayloadDisplayName</key> <string>Wi-Fi (spacenet)</string> <key>PayloadIdentifier</key> <string>com.apple.wifi.managed.DACD46DA-FB49-4B30-AA0E-120A67808D73</string> <key>PayloadOrganization</key> <string></string> <key>PayloadType</key> <string>com.apple.wifi.managed</string> <key>PayloadUUID</key> <string>DACD46DA-FB49-4B30-AA0E-120A67808D73</string> <key>PayloadVersion</key> <integer>1</integer> <key>ProxyType</key> <string>None</string> <key>SSID_STR</key> <string>spacenet</string> </dict> <dict> <key>PayloadCertificateFileName</key> <string>revspace-wifi-ca.crt</string> <key>PayloadContent</key> <data> LS0tLS1CRUdJTiBDRVJUSUZJQ0FURS0tLS0tCk1JSUR6akNDQXJZ Q0NRRGFydk5oUkwwaFNUQU5CZ2txaGtpRzl3MEJBUXNGQURDQnFE RUxNQWtHQTFVRUJoTUMKVGt3eEN6QUpCZ05WQkFnTUFscElNUkV3 RHdZRFZRUUhEQWhFWlc0Z1NHRmhaekVqTUNFR0ExVUVDZ3dhVTNS cApZMmgwYVc1bklGSmxkbVZzWVhScGIyNGdVM0JoWTJVeEVUQVBC Z05WQkFzTUNGSmxkbk53WVdObE1SOHdIUVlEClZRUUREQlptYkhW NExuTndZV05sTG5KbGRuTndZV05sTG01c01TQXdIZ1lKS29aSWh2 Y05BUWtCRmhGaWIyRnkKWkVCeVpYWnpjR0ZqWlM1dWJEQWVGdzB5 TVRFeU1EUXlNRE0zTlROYUZ3MDBPVEEwTWpBeU1ETTNOVE5hTUlH bwpNUXN3Q1FZRFZRUUdFd0pPVERFTE1Ba0dBMVVFQ0F3Q1drZ3hF VEFQQmdOVkJBY01DRVJsYmlCSVlXRm5NU013CklRWURWUVFLREJw VGRHbGphSFJwYm1jZ1VtVjJaV3hoZEdsdmJpQlRjR0ZqWlRFUk1B OEdBMVVFQ3d3SVVtVjIKYzNCaFkyVXhIekFkQmdOVkJBTU1GbVpz ZFhndWMzQmhZMlV1Y21WMmMzQmhZMlV1Ym13eElEQWVCZ2txaGtp Rwo5dzBCQ1FFV0VXSnZZWEprUUhKbGRuTndZV05sTG01c01JSUJJ akFOQmdrcWhraUc5dzBCQVFFRkFBT0NBUThBCk1JSUJDZ0tDQVFF QXFlVk9pUFltMUhkRTBiN0V4Z081VDhLQ1pUUnh5TEFhcVBUNnpr ZUFWdnVtRm5LYnc2RmIKTlJJY24xUm8vWEQyL1l3TVNVTDJjeXYw MnVheVVnaVJnY213YWpmRmhmaW1nWEo5NnVrM3F2QXNPNHBWeTN4 dgpxZ2VUeTZ5dkVoaXJTQmQ5dThoRU9VMWt4UktUOGlnUUlXSDdj aTRLWTZDK1JEZVpsZGYxZnlKbnJPTWk0eU9FCmVaWENDSG9YWTZK UE8waU1zMXo1cXk4Rk82VExWTlY4eHRqb3h6TUdPMHp5UzdCZDZ2 TmI1Q2l5d0svU29nUGcKWU55djQ0ODRrWjR5dkxOMHV1a0RZTWM4 cFJWb2JNU2Jjb256NWVKMG9sR3pYeGpwNGNSeHBUU1l6QlVvQXZt MApOMUJCamp3amhGVHZqMTNITks0N2NYZDVadkhMSDdQREN3SURB UUFCTUEwR0NTcUdTSWIzRFFFQkN3VUFBNElCCkFRQWhFWkxKNnhr eExaNDAzcDBWRlhON05mMmVuRWVrV08yY2ErcXdLRmRScGhUMDdn SUdod0h3d0RGQW0zMWoKSWNCcVZOUFpwLy9pYnVYcXBMVit1Q09D Y3JUWStKN0ZYM3ljU0l3L1Y3aVBFSmpBZWY0dmJHMDkvTitPbWkz bwo3Q0p1eXp6NGxXYnMwQmQ3U0dNZTF2bFRzV1hBMHZUZUdDU0ND UU9XYStpejcwYkFLYzQwVUIrV01EWnh4b3ppCmdhQXllMHB2VTF2 a00vNlVkVndVNjErMVJOckFFTW4wNFpkZDNFTEI2S1VyZlY5QlR6 ZnZZb1BJNXRnbDdibW4KdHpPdURkQzU2S0lwM0JFTk5ic3VBY21u NVhPcGwxS2FPblM0ejJEanA3RXBObUl6eXZPcmJDbVUrZXhaeU1m MgpyUmtvVmw2MWlXdy8reDRYcGliT2F3T0IKLS0tLS1FTkQgQ0VS VElGSUNBVEUtLS0tLQo= </data> <key>PayloadDescription</key> <string>Adds a CA root certificate</string> <key>PayloadDisplayName</key> <string>flux.space.revspace.nl</string> <key>PayloadIdentifier</key> <string>com.apple.security.root.7060659C-7F19-4F0C-B292-505D8A41E9A9</string> <key>PayloadType</key> <string>com.apple.security.root</string> <key>PayloadUUID</key> <string>7060659C-7F19-4F0C-B292-505D8A41E9A9</string> <key>PayloadVersion</key> <integer>1</integer> </dict> </array> <key>PayloadDescription</key> <string>This profile allows you to connect to the Spacenet wifi.</string> <key>PayloadDisplayName</key> <string>revspace</string> <key>PayloadIdentifier</key> <string>revspace.wifi</string> <key>PayloadOrganization</key> <string>Revspace</string> <key>PayloadRemovalDisallowed</key> <false/> <key>PayloadType</key> <string>Configuration</string> <key>PayloadUUID</key> <string>7CC8815D-0F2D-413B-99C7-B9B9DDD1A300</string> <key>PayloadVersion</key> <integer>1</integer> </dict> </plist>
