Its-g5
| Project ITS-G5 | |
| Investigating ITS-G5 signals | |
| Last Update | 2026-06-24 |
Stuff to investigate:
- Source code for an ITS-G5 receiver https://github.com/pit711/v2x2map
- Crowd-sourced live map of messages received: https://opentrafficmap.org/
- Simplest source code for Arduino-based sniffer: https://git.devlol.org/jstsmthrgk/simple-its-g5-receiver-firmware
- How to contribute to opentrafficmap: https://wiki.opentrafficmap.org
Design
The plan is:
- Use an esp32-c5 for sniffing 802.11p frames only
- Use an esp32-c3 (as an inexpensive jellybean part) for receiving sniffed frames from the esp32-c5, connect to WiFi and upload packets over MQTT
- The interface beteween the two boards is serial, this is simpler than SPI as used in other projects:
- Only three wires required: GND, +5V and serial DATA
- No need to desolder capacitors on SPI wires of the esp32-c5
- A serial interface is more universal, e.g. can be connected to an arbitrary linux SBC, to run a python bridge for example
- On the esp32-c5 use the same wires as the existing USB-UART bridge, so you can also receive packets over USB-serial
- Run a simple web server on the esp-c3:
- Configuration page with MQTT settings: host, port, user, pass, base topic
- Perhaps configure a keystore/certificate for secure mqtt (mqtts), if needed
- Optional: show some nice stats: mqtt status, packet rate, last packet, packets per type
- Optional: run a very basic parser for e.g. CAM messages
Practical:
- The serial link runs over the USB-UART chip of the esp32-c5.
- A simple command processor runs on the other UART (the emulated USB serial port)
- On the esp32-c5 side, use pins GND, 5V, GPIO25 for the ESP-ESP serial connection. These pins are right next to each other on the esp32-c5-devkitc-1. Pin GPIO25 is the pin that connects to the USB-UART chip.
- The esp32-c3 and esp32-c5 have their 5V power lines connected together. Each board derives its own internal power supplies from this 5V.
- The serial link probably doesn't have to be very high speed, start with 115200 for example. Try to use a hardware serial peripheral on both sides for this.
- Probably use the Arduino PacketSerial library on both sides for framing/deframing packets.
I got this ESP-C5-devkitC-1 board, and it worked for me:
- aliexpress product page https://nl.aliexpress.com/item/1005012416463528.html
- espressif schematic https://dl.espressif.com/dl/schematics/SCH_ESP32-C5-DevkitC-1_V1.1_20240621.pdf . Actually my board is not exactly like this, the USB-UART is connected to pins GPIO11 (TX) and GPIO12 (RX), not
- espressif devkit-c page: https://docs.espressif.com/projects/esp-dev-kits/en/latest/esp32c5/esp32-c5-devkitc-1/user_guide.html
It has an onboard antenna. There are also other boards with an antenna connection, which allows using an external antenna. This may be better, I don't know yet.
See https://github.com/bertrik/its-g5-receiver
Compiling the firmware
Uses python an platformio, see the README.md in the source archive.
Watch packets come in:
pio device monitor
Then viewed in wireshark:
wireshark message.pcap
opentraffic map interface
See https://github.com/MPW1412/openwrt-otm-bridge#wire-format-mimics-the-esp32-c5-firmware for the mqtt wire format.
See also https://github.com/pit711/v2x2map/blob/main/firmware/main/mqtt.c
