ZX81plus38 simple to build ZX-81 clone
Project ZX81plus38
Contact mahjongg
Last Update 2021-04-21
P.S. No I won't!
October 1, 2019 continued
px800
January 28, 2020
February 12, 2020
February 19, 2020
February 26, 2020
March 4, 2020 layout finished
and this is the bottom layer:
and bottom view
March 16, RefSpace is closed!
The jumpers are:
and bottom:
my GitHub page is here: [2]
I managed to work from home
Now the clone should work.
and bottom:
and this is the bottom side:
P.S. I went to a cardiologist to have my heart checked out, but there doesn't seem to be any problem with my heart. Very soon I will be vaccinated for covid. Hopefully this will give me a bit more energy as my energy level has been very low. I have not done much work on my own prototype (revision 1.6 board) I just soldered about 3/4 of the sockets. Hopefully I will do some more soon. I'm curious if it works exactly as I expect it, especially if the loading bar emulation logic works exactly as I planned. Several builder have announced that the revision 1.6 now works "perfectly" (for them). I also need to get my earlier keyboard PCB, which I suspect is still at Revspace.
