ZX81plus38 simple to build ZX-81 clone
Revision as of 15:46, 21 April 2021 by Mahjongg (talk | contribs)
Project ZX81plus38
Contact mahjongg
Last Update 2021-04-21
P.S. No I won't!
October 1, 2019 continued
px800
January 28, 2020
February 12, 2020
February 19, 2020
February 26, 2020
March 4, 2020 layout finished
and this is the bottom layer:
and bottom view
March 16, RefSpace is closed!
The jumpers are:
and bottom:
my GitHub page is here: [2]
I managed to work from home
Now the clone should work.
and bottom:
and this is the bottom side:
