ZX81plus38 simple to build ZX-81 clone
Project ZX81plus38
Bestand:ZX81+38rev1,5 top.png.PNG
Most people I showed my ZX-81 clone (ZX81+35) said they liked it, but with such a tiny board and with so many "difficult" surface mount components, they doubted whether they would be able to build this kit, so I restarted my effort, to try to build a 100% compatible ZX-81 clone that anybody could build, with commonly available pin-through-hole parts.
Contact mahjongg
Last Update 2020-10-15
P.S. No I won't!
October 1, 2019 continued
Schematic finished for rev 1.0, updated schematic Bestand:ZX81plus38.pdf, plus preview schematic pictures. Next up, importing the components in the PCB layout, and placement of the parts. No attempts have been made yet to try to support multiple types of ROM/EPROM/FLASH, like the original ZX81 ROM. But this schematic should be complete. New is my attempt to support the canonical cassette loading video bars.
Schematic is now revision 1.1 Bestand:ZX81plus38 rev 1.1.pdf
Revision 1.2: Bestand:ZX81plus38 rev1.2.pdf
I realized that some people might want to extend the Sinclair BASIC ROM, or replace it with something else, and might need a larger ROM, so I added a (virtual) jumper to enable 16K ROM's to the ROM encoder and added A13 to the EEPROM address lines. revision 1.3 with 16K ROM support: Bestand:ZX81plus38 rev1.3.pdf
px800
Now the schematic is updated to revision 1.4. Bestand:ZX81plus38rev 1.4.pdf due to swapped ports.
January 28, 2020
February 12, 2020
February 19, 2020
February 26, 2020
March 4, 2020 layout finished
and this is the bottom layer:
and bottom view
March 16, RefSpace is closed!
The jumpers are:
and bottom:
my GitHub page is here: [2]
I managed to work from home
I finished the promised schematic in black and white, also found and corrected a few minor mistakes, 620 Ohm resistors do not exist in the E12 range and should be 680 Ohm, and RP2 was named incorrectly. this is the final schematic of 12 September 2020: Bestand:ZX81plus38Rev1.4BW.pdf
I also finished the BOM of the ZX81+38, so now you can order the components. I used two sources for components, as neither of the to had all the components that are necessary. I used farnell and mouser as suppliers, and between them they had everything that is necessary to build this ZX-81 clone. This is the spreadsheet in open office (.ODS) format. Bestand:ZX81plus38 BOM.ods.
In this schematic all the reported faults and requested improvements are implemented. Bestand:ZX81plus38rev1,5.pdf
Now the clone should work.
