ZX81plus38 simple to build ZX-81 clone
Revision as of 10:43, 11 March 2020 by Mahjongg (talk | contribs)
Project ZX81plus38
Most people I showed my ZX-81 clone (ZX81+35) said they liked it, but with such a tiny board and with so many "difficult" surface mount components, they doubted whether they would be able to build this kit, so I restarted my effort, to try to build a 100% ZX-81 clone that anybody could build, with commonly available pin-through-hole parts.
Status Initializing
Contact mahjongg
Last Update 2020-03-11
October 1, 2019 continued
px800
January 28, 2020
February 12, 2020
February 19, 2020
February 26, 2020
March 4, 2020 layout finished
and this is the bottom layer:
and bottom view
