Luteijn/Vortex
Project "Vortex":
Project Luteijn/Vortex
Contact Luteijn
Last Update 2018-02-05
http://wiki.dfrobot.com.cn/index.php?title=(SKU:ROB0116)_Vortex%E5%8F%AF%E7%BC%96%E7%A8%8B%E6%9C%BA%E5%99%A8%E4%BA%BA#.E6.A0.B7.E4.BE.8B.E4.BB.A3.E7.A0.81
What's connected to the pins
Connection overview
0 Serial RX (input)
1 Serial TX (output)
2 Encoder Wheel (External Interrupt 0) (input)
3 Encoder Wheel (External Interrupt 1) (input)
4 ?? mp3 RX (input) hopefully but don't know. Doesn't seem to be it, and can't really trace where it is going.
5 Motor 0 Speed (PWM) (output)
6 Motor 1 Speed (PWM) (output)
7 IR decoder/detector (input)
8 IR led Left (output)
9 Motor 0 direction (H=forwards,L=reverse) (output)
10 Motor 1 direction (output)
11 MP3-player TX (output)
12 IR led Right (output)
13 GRB LED chain around body (output)
A0 grayscale 4 'D' (input)
A1 grayscale 3 'C' (input)
A2 grayscale 2 'B' (input)
A3 grayscale 1 'A' (input)
A4 SDA (i2c)
A5 SCL (i2c)
A6 grayscale 5 'E' (input)
A7 grayscale 6 'F' (input)
i2c bus + Vcc & Gnd should be available at 4 pin rear expansion port too - need to find a suitable connector for it..
http://www.hobbytronics.co.uk/arduino-atmega328-pinout Useful diagrams to map pins to package
Dumping original firmware
Although you can/should be able to reflash Vortex with the App, might as well make a backup of the orignal:
avrdude -c arduino -p m328p -P /dev/ttyACM0 -U flash:r:"Vortex.hex":i
This can be uploaded again with:
avrdude -c arduino -p m328p -P /dev/ttyACM0 -U flash:w:"Vortex.hex":i
(The app might also be initializing other things, but this seems to work)
Your own sketches can be uploaded with
arduino --upload MySketch.ino
But using avrdude to upload the .hex file is a bit quicker.
Motor Control
int E1 = 5;
int M1 = 9;
int E2 = 6;
int M2 = 10;
void setup()
  pinMode(M2, OUTPUT);
void loop()
  int value;
  for(value = 0 ; value <= 255; value+=5)    //foreward
    digitalWrite(M1,HIGH);
    digitalWrite(M2, HIGH);
    analogWrite(E1, value);   //PWM Speed control
    analogWrite(E2, value);   //PWM Speed Control
    delay(30);
  for(value = 0 ; value <= 255; value+=5)   //backward
    digitalWrite(M1, LOW);
    digitalWrite(M2, LOW);
    delay(30);
Encoders
long leftPul,rightPul;
void leftCallBack(){
  leftPul++;
void rightCallBack(){
  rightPul++;
void initDdevice(){
    pinMode(5,OUTPUT);
    pinMode(6,OUTPUT);
    pinMode(9,OUTPUT);
    pinMode(10,OUTPUT);
    noInterrupts();
    interrupts();
void motorDebug(){
  digitalWrite(5,HIGH);
  digitalWrite(6,HIGH);
  digitalWrite(9,HIGH);
  digitalWrite(10,HIGH);
void printPul(){
  Serial.print(leftPul);
  Serial.print(" ");
  Serial.println(rightPul);
  leftPul = 0;
  rightPul = 0;
void setup() {
  initDdevice();
  Serial.begin(9600);
  motorDebug();
void loop() {
  printPul();
  delay(500);
Analogue Inputs
       2 (a2) 3 (a1)
1 (a3)               4 (a0)
5 (a6)               6 (a7)
void setup(void){
 Serial.begin(9600);
int analogBuf[6] = {'\0'};
void loop(void){
  analogBuf[0] = analogRead(3);
  analogBuf[1] = analogRead(2);
  analogBuf[2] = analogRead(1);
  analogBuf[3] = analogRead(0);
  analogBuf[4] = analogRead(6);
  analogBuf[5] = analogRead(7);
  for(int i=0;i<6;i++){
    Serial.print(i+1);
    Serial.print(": ");
    Serial.print(analogBuf[i]);
    Serial.print("   ");
  Serial.println();
  delay(500);
LEDs
  FastLED.addLeds<WS2811, DATA_PIN, GRB>(leds, NUM_LEDS);
IR obstacle detector
Seems to be somewhat flaky. Needs a bit more work to figure out. Also, the IR sensor is useful to read IR remote controllers or beacons. This receiver seems to work at 38kHz, but probabbly also reacts to 36-40kHz. Remote controllers often work at 36kHz. Note that 2x 8µs delay doesn't give you 38kHz, but the digitalWrite itself also induces quite some delay (3-6µs), so seems this is bringing the total period up to around the 26.something µs we'd expect.
#define NUM_LEDS 12
// Data pin that led data will be written out over
#define DATA_PIN 13
CRGB leds[NUM_LEDS];
#define IR_IN  7//IR receiver pin
#define L_IR 8  //left ir transmitter pin
int count;
  int i;
  for(i=0;i<24;i++){
    digitalWrite(L_IR,LOW);
    delayMicroseconds(8);
    digitalWrite(L_IR,HIGH);
  int i;
  for(i=0;i<24;i++){
    digitalWrite(R_IR,LOW);
    digitalWrite(R_IR,HIGH);
    PCICR |= 1 << PCIE2;
  count++;
void obstacleAvoidance(void){
  char i;
  count=0;
   leds[5] = CRGB::Green;
   FastLED.show();
  for(i=0;i<20;i++){  //left transmitter sends 20 pulses
    leftSend38KHZ();
    delayMicroseconds(600);
    leds[5] = CRGB::White;
    FastLED.show();
    Serial.println("Left");
    delay(100);
  count=0;
  leds[3] = CRGB::Green;
  FastLED.show();
    rightSend38KHZ();
    leds[3] = CRGB::White;
    FastLED.show();
    Serial.println("Right");
    delay(100);
  delay(600);
void setup(void){
  delay(2000);
  Serial.begin(9600);
  leds[4] = CRGB::Blue;
  FastLED.show();
  delay(2000);
  leds[4] = CRGB::Purple;
  FastLED.show();
  noInterrupts();
  pcint0Init();
  interrupts();             //enable the interrupt
void loop(void){
    obstacleAvoidance();
IRreceiver
#include "IRremote.h"
IRrecv irrecv(IR_IN);
decode_results results;
void setup(void){
  Serial.begin(9600);
  irrecv.enableIRIn(); // Start the receiver
void loop(void){
  if (irrecv.decode(&results)) {
    irrecv.resume(); // Receive the next value
The receiver is mounted on the front, bottom. So not right between the eyes, although a spot seems to be prepared for it there too.
The tables at Luteijn/IRRemotes might be useful when creating a sketch that is to be controlled over IR.
MP3-player
#define MP3_VOLUME 0x10
#define TX 11
#define RX 4  // ?? was 2 in example I found, but that is unlikely
#include <SoftwareSerial.h>
void setup()
  delay(1000);
  mp3Init();
  mp3setVolume(30);//0~30
void loop()
  mp3player(1);
  delay(2000);
  mp3stop();
  delay(1000);
void mp3Init()
    mySerial.begin (9600);
void mp3setVolume(byte vol)
    mySerial.write(buffer, 8);
    delay(20);
void mp3player(byte data)
    delay(20);
void mp3stop()
https://www.dfrobot.com/product-1121.html , documented at https://www.dfrobot.com/wiki/index.php/DFPlayer_Mini_SKU:DFR0299 is a mini-MP3 player from DFRobot. It is controllable over serial, and might be the same one as used in the Vortex. Would be good to figure out if the 'busy' signal and/or the serial TX are connected back to the arduino somewhere in that case. Player could also be a variant but the magic numbers more or less match (although the stop command 0x16 is not in the table.
The MP3-chip inside Vortex has Part# YX6100-24SS. Seems to be part of a family of serial MP3-players made by "广州悦欣电子科技有限公司" --> "Guangzhou Yue Xin Electronic Technology Co., Ltd." - website http://www.yx080.com/mp3xinpian/53-15.html has a download link on this yx6100 page but it seems to just refer us to the 5200 application Manual V1.8, which appears to be mostly compatible. The command table for the chip does include a 0x16 stop command.
Also the datasheet mentions the chip can play both MP3 and WAV. YX5300-24SS is a similar part, datasheet at https://xp-dev.com/trac/arduino_antonio/export/280/arduino_antonio/trunk/EnterpriseBase/Serial%20MP3%20Player/About%20the%20Chip%20-%20YX5300/YX5300-24SS%20Datasheet%20V1.0.pdf The command table for that chip does include a 0x16 stop command.
Format: $S VER Len CMD Feedback para1 para2 checksum $O
$S Start byte 0x7e Each command begins with 0x7e ('~')
VER Version information Version seems to be 0xff from the example
Len the number of bytes Start, End and Checksum are not counted,
CMD Commands See command table.
Feedback Command feedback 1: feedback, 0: no feedback ; need to test what this does, might mean 'echo'
Para1 Parameter 1 Query high data byte
Para2 Parameter 2 Query low data byte
checksum Checksum accumulation and verification, doesn't include start byte. Seems to be 2 bytes from the example given in the docs, but Vortex seems to just not need it put in. example given is 7e ff 06 09 00 00 04 ff dd ef ; The 5200 Datasheet uses the exact same example command, and explains that you should add all the bytes, and then subtract those from 0 to get the checksum. The 5300 Datasheet also mentions "另外用户也可以直接忽视校验,参考我们的5.3.4 章节说明。" so looks like the checksum is optional if you don't care too much about corruption of the occasional command.
$O End byte End of command is signaled with 0xEF
Command table WIP to copy this over
CMD Function Description Parameters (16 bit) compared with YX5300 info
0x01 Next
0x02 Previous
0x03 Specific track 0-2999 but example is only using low byte. also track 0 doesn't seem to do anything? Indicates 1-255 are the valid tracks only.
0x04 Volume up
0x05 Volume down
0x06 Set Volume 0-30 (10 is already quite loud!)
0x07 Specify EQ(0/1/2/3/4/5/) Normal/Pop/Rock/Jazz/Classic/Base. Reserved in the 5300's command list.
0x08 Specify playback mode (0/1/2/3) Repeat/folder repeat/single repeat/random See 3.4.3; this explains the argument is the song to play in a loop - may have been changed for 6100
0x09 Select source (0/1/2/3/4) U/TF/AUX/SLEEP/FLASH See 3.4.4; specifies 1 as U, 2 as TF, 4 as PC, 5 FLASH and 6 SLEEP
0x0a Enter into standby - low power loss Sleep - Low power consumption 10MA (obviously mA or µA, not MA, is meant)
0x0b Normal working Wake up from sleep
0x0c reset module chip reset
0x0d Playback Play - seems to be contrast to suspend/pause
0x0e Pause Suspended
0x0f Specify folder to playback 1~10(need to set by user) see 3.4.5 - DH: represents the name of the folder, the default support for 99 files, 01 - 99 named DL: represents the track, the default maximum of 255 songs, that is, 0x01 ~ 0xFF
0x10 Volume adjust set DH=1:open volume adjust DL: set volume gain 0~31 not present in command table
0x11 Repeat play 1:start repeat play 0: stop play not present in command table
0x16 not in the table example mentions it as a stop command Stop
0x17 not in the table FLASH only, see 3.4.7 (but is in section 3.4.6), select folder to loop.
0x18 not in the table Reserved
0x19 not in the table See 3.4.8 (but is in section 3.4.7), select loop current track mode
0x21 not in the table See 3.4.9 (3.4.8), set DAC to High-Z mode (1) or on (0) so you can use the amp for something else.
0x22 not in the table See 3.4.10 (section 3.4.9 doesn't exist), Set volume and song to play in one command (H:volume L:track)
0x3C STAY Reserved
0x3D STAY Reserved
0x3E STAY Reserved
0x3F Send initialization parameters 0-0x0F (each bit represent one device of the low-four bits) Seems to be reporting which storage devices are currently online (see section 3.5.1)
0x40 Returns an error, request retransmission Probably this is a response to a command meaning Error Encountered.
0x41 Answer Probably this is a response to a query and just means Accepted.
0x42 Query Status See 3.4.10 (actually 3.5.2) - explains that this will return which storage is used and if it's playing, stopped or paused. The storage could also be 'SLEEP' to indicate sleeping?
  uint16_t sum = 0;
    sum += buffer[i];
  return -sum;
Eyes
The 'Eyes' are connected over i2c. The daughterboard they are on features an STM8S103K3 (see http://www.st.com/en/microcontrollers/stm8s103-105.html ) and 2x HC595 (shift registers). Besides 35 predefined eye patterns, it is also possible to upload your own eye patterns.
#include <Wire.h>
#define I2C_WRITE   0x00
uint8_t serial=0;
void setup(){
   Wire.begin(); // join i2c bus (address optional for master)
   defined_eyes(6,1);
   delay(2000);
void loop(){
   defined_eyes(1,serial);
   serial++;
   if(serial>=35) serial=0;
   delay(250);
   Wire.beginTransmission(I2C_LED_ADDRESS << 1 | I2C_WRITE); // transmit to device #4
// (I suppose they mean 0x40, although eyes seem to also respond on 0xC0 which is what is defined above, and 0x20)
   Wire.write(serial);  //preset eyes 0~34
   Wire.endTransmission();    // stop transmitting
void custom_eyes(uint8_t color, uint8_t eyeline[10]){
   uint8_t index;
   // right eye         left eye
   //1  2  3  4  5      25 24 23 22 21
   //6  7  8  9  10     20 19 18 17 16
   //11 12 13 14 15     15 14 13 12 11
   //16 17 18 19 20     10 9  8  7  6
   //21 22 23 24 25     5  4  3  2  1
   Wire.write(0x55);  // color 55=custom eyes follow
   Wire.write(0xAA);  // ?? AA=color followed by 10 bytes, each defining one line
   Wire.write(color&0x7);         //color 1-B,2-G,4-R of foreground
   for (index=0;index<10;index++) {
     Wire.write(eyeline[index]);
void example_eyes() {
   Wire.write(0x1c);
   Wire.write(0x18);
   Wire.write(0x10);
   Wire.write(0x1f);  // top row all 5 bits lit
   Wire.write(0x0f);  // leds 6,7,8,9 on 10 off
   Wire.write(0x07);  // 11,12,13 on,  14,15 off
   Wire.write(0x03);
   Wire.write(0x01);
KITT-scanner / Cylon
#include <Wire.h>
#include <IRremote.h>
#define MTX (11)
#define MRX (4)
// Song number for "By your command"-sample
#define BYC (30)
// Song number for Warble
#define Warble (31)
#define IR_IN (7)
#define I2C_LED_ADDRESS 0x80
bool left=1;
SoftwareSerial mp3(MRX,MTX);
short command=0;
uint8_t eyes[10]={0x00,0x00,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
void setup(){
  mp3Init();
  delay(2000);
  delay(100);
  mp3setVolume(10);//0~255, but 30 is already quite loud!
  delay(50);
  mp3player(Warble);
  delay(50);
  mp3repeat(2); // repeat once
  delay(50);
  mp3player(BYC);
  delay(3000);
  mp3setVolume(8);//0~255, but 30 is already quite loud!
  delay(50);
  mp3player(Warble);
  delay(50);
  mp3repeat(0); // repeat forever
  delay(50);
void lscroll_eyes(uint8_t * eyes ){
  uint8_t i;
  eyes[2]=(uint8_t)(eyes[2]<<1);
  eyes[7]=(uint8_t)(eyes[7]<<1);
void rscroll_eyes(uint8_t * eyes ){
  uint8_t i;
  eyes[2]=(uint8_t)(eyes[2]>>1);
  eyes[7]=(uint8_t)(eyes[7]>>1);
  uint8_t index;
  Wire.beginTransmission(I2C_LED_ADDRESS); // 0x4 preshifted to 0x8 and lsb set to 0 for write
  Wire.write(0x55);  // register 55=?custom eyes
void loop(){
  // 1 2 4 8 10 '20' 10 8 4 2 1
  if (left) {lscroll_eyes(eyes);}
  else if (!left) {rscroll_eyes(eyes);}
  custom_eyes(4,eyes);
  if (eyes[7]==0x1) {left=1;}
  else if (eyes[2]==0x1) {left=1;}
  else if (left && eyes[2]>=0x10) {eyes[2]=0;eyes[7]=0x20;left=0;}
  else if (left && eyes[7]>=0x10) {eyes[7]=0;eyes[2]=0x20;left=0;}
  if (irrecv.decode(&results)){
    if (command) {
      command=0;
    } else{
      command=34; // adjust to match sample length
      mp3player(BYC);
      delay(50);
    irrecv.resume();
  } else {
    if (command) {
      command--;
      if (!command){
        mp3player(Warble);
        delay(50);
      } else {
        delay(80);
    } else {
      delay(80);
void mp3Init()
  uint8_t buffer[] = {0x7e, 0xff, 0x06, 0x0C, 0x00, 0x00, 0x00, 0xef};
  mp3.begin(9600);
  delay(100);
  mp3.write(buffer, 8);
  delay(100);
void mp3repeat(byte data)
  uint8_t buffer[] = {0x7e, 0xff, 0x06, 0x08, 0x00, 0x00, data, 0xef};
Conway's Game of Life
2 5x5 fields linked as a torus of 10x5. Change mapping of cells in the edge to make e.g. a front and a back side, or change to 8x8 and add 4 more faces and a bit more mapping to create an LED cube of 6 faces.
include <Wire.h>
#define IR_IN (7)
 // 5x5 matrix eye
#define CX (5)
#define CY (5)
// edge of 1 cell on each end
#define CXM (7)
#define CYM (7)
#define F (2) // 2 faces have I.
uint8_t eyes[10];
uint8_t board_a[F][CYM][CXM];
uint8_t board_b[F][CYM][CXM];
inline void clear(uint8_t board[][CYM][CXM]) {
  uint8_t i,j,k;
  for (k=0;k<F;k++) {
    for (j=0;j<CYM;j++) {
      for (i=0;i<CXM;i++) {
        board[k][j][i]=0;
inline uint8_t neighbors(uint8_t s[][CYM][CXM], uint8_t k,uint8_t j,uint8_t i) {
  return s[k][j-1][i-1]+s[k][j-1][i]+s[k][j-1][i+1]+s[k][j][i-1]+s[k][j][i+1]+s[k][j+1][i-1]+s[k][j+1][i]+s[k][j+1][i+1];
inline void play(uint8_t s[][CYM][CXM], uint8_t d[][CYM][CXM]) {
  uint8_t i,j,k;
 // TODO: load edges from right faces hardcoded for 5x5 now
  for (i=1;i<=5;i++) {
    s[0][0][i]=s[0][5][i];
    s[0][6][i]=s[0][1][i];
    s[0][i][0]=s[1][i][5];
    s[0][i][6]=s[1][i][1];
    s[1][0][i]=s[1][5][i];
    s[1][6][i]=s[1][1][i];
    s[1][i][0]=s[0][i][5];
    s[1][i][6]=s[0][i][1];
  // corners
    s[0][0][0]=s[1][5][5];
    s[0][6][0]=s[1][1][5];
    s[0][0][6]=s[1][5][1];
    s[0][6][6]=s[1][1][1];
    s[1][0][0]=s[0][5][5];
    s[1][6][0]=s[0][1][5];
    s[1][0][6]=s[0][5][1];
    s[1][6][6]=s[0][1][1];
 // update interior cells
  for (k=0;k<F;k++) {
    for (j=1;j<=CY;j++) {
      for (i=1;i<=CX;i++) {
        switch (neighbors(s,k,j,i)) {
          case 2: d[k][j][i]=s[k][j][i]; // remain
                  break;
          case 3: d[k][j][i]=1; // birth
                  break;
          default: d[k][j][i]=0; // death
inline uint8_t convert_l(uint8_t l[CXM]) {
return (l[5]|l[4]<<1|l[3]<<2|l[2]<<3|l[1]<<4);
inline uint8_t convert_r(uint8_t l[CXM]) {
return (l[1]|l[2]<<1|l[3]<<2|l[4]<<3|l[5]<<4);
inline uint8_t * board_to_eyes(uint8_t board[F][CYM][CXM]) {
  static uint8_t eyes[10]={0,0,0,0,0,0,0,0,0,0};
  eyes[0]=convert_l(board[1][5]);
  eyes[1]=convert_l(board[1][4]);
  eyes[2]=convert_l(board[1][3]);
  eyes[3]=convert_l(board[1][2]);
  eyes[4]=convert_l(board[1][1]);
  eyes[5]=convert_r(board[0][1]);
  eyes[6]=convert_r(board[0][2]);
  eyes[7]=convert_r(board[0][3]);
  eyes[8]=convert_r(board[0][4]);
  eyes[9]=convert_r(board[0][5]);
  return eyes;
void dump(uint8_t b[][CYM][CXM]) {
  uint8_t i,j,k;
  Serial.println("==");
  for (k=0;k<F;k++) {
        Serial.print(b[k][j][i]?'x':'o');
      Serial.println("");
void setup(){
  delay(2000);
  Serial.begin(9600);
  Serial.println("life");
  clear(board_a); // start with empty board a
  clear(board_b); // start with empty board b
  //some initial state:
  board_a[0][1][2]=1;
  board_a[0][2][3]=1;
  board_a[0][3][1]=1;
  board_a[0][3][2]=1;
  board_a[0][3][3]=1;
  board_a[1][1][2]=1;
  board_a[1][2][3]=1;
  board_a[1][3][1]=1;
  board_a[1][3][2]=1;
  board_a[1][3][3]=1;
  Serial.println("inited");
inline void custom_eyes(uint8_t color, uint8_t eyeline[10]){
  uint8_t index;
void loop(){
//  dump(board_a);
  custom_eyes(4,board_to_eyes(board_a));
  play(board_a,board_b);
  delay(50);
//  dump(board_b);
  custom_eyes(4,board_to_eyes(board_b));
  play(board_b,board_a);
  delay(50);
//TODO: add something to react to remote here, e.g. set some cells etc.
    irrecv.resume();
  } else {
i2c
There might be more stuff connected to the i2c already, I plan to do some tests to find out. Would be nice if e.g. the flash of the mp3 player or some other expansion was already there.
Regardless of what's there already, Vortex seems to be designed to be extended over i2c, and could be a nice platform to do some experiments/demo's with.
Here's a simple scanning sketch, looks like only 0x40 has something connected, and that would be the eye-display.
#include <Wire.h>
void setup()
  Wire.begin();
  Serial.begin(9600);
  while (!Serial);             // Leonardo: wait for serial monitor
  Serial.println("\nI2C Scanner");
void loop()
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 0; address < 128; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.print("  (");
      Serial.print(address,DEC);
      Serial.println("d)  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknown error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print("  (");
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
  else
    Serial.println("done\n");
  delay(5000);           // wait 5 seconds for next scan
