Luteijn/Vortex
Revision as of 11:31, 31 January 2018 by Luteijn (talk | contribs)
Project "Vortex":
Project Luteijn/Vortex
Contact Luteijn
Last Update 2018-01-31
http://wiki.dfrobot.com.cn/index.php?title=(SKU:ROB0116)_Vortex%E5%8F%AF%E7%BC%96%E7%A8%8B%E6%9C%BA%E5%99%A8%E4%BA%BA#.E6.A0.B7.E4.BE.8B.E4.BB.A3.E7.A0.81
Motor Control
int E1 = 5;
int M1 = 9;
int E2 = 6;
int M2 = 10;
void setup()
  pinMode(M2, OUTPUT);
void loop()
  int value;
  for(value = 0 ; value <= 255; value+=5)    //foreward
    digitalWrite(M1,HIGH);
    digitalWrite(M2, HIGH);
    analogWrite(E1, value);   //PWM Speed control
    analogWrite(E2, value);   //PWM Speed Control
    delay(30);
  for(value = 0 ; value <= 255; value+=5)   //backward
    digitalWrite(M1, LOW);
    digitalWrite(M2, LOW);
    delay(30);
Encoders
#define pinInputLeft 0
#define pinInputRight 1
long leftPul,rightPul;
void leftCallBack(){
  leftPul++;
void rightCallBack(){
  rightPul++;
void initDdevice(){
    pinMode(5,OUTPUT);
    pinMode(6,OUTPUT);
    pinMode(9,OUTPUT);
    pinMode(10,OUTPUT);
    noInterrupts();
    interrupts();
void motorDebug(){
  digitalWrite(5,HIGH);
  digitalWrite(6,HIGH);
  digitalWrite(9,HIGH);
  digitalWrite(10,HIGH);
void printPul(){
  Serial.print(leftPul);
  Serial.print(" ");
  Serial.println(rightPul);
  leftPul = 0;
  rightPul = 0;
void setup() {
  initDdevice();
  Serial.begin(9600);
  motorDebug();
void loop() {
  printPul();
  delay(500);
Analogue Inputs
       2 (a2) 3 (a1)
1 (a3)               4 (a0)
5 (a6)               6 (a7)
void setup(void){
 Serial.begin(9600);
int analogBuf[6] = {'\0'};
void loop(void){
  analogBuf[0] = analogRead(3);
  analogBuf[1] = analogRead(2);
  analogBuf[2] = analogRead(1);
  analogBuf[3] = analogRead(0);
  analogBuf[4] = analogRead(6);
  analogBuf[5] = analogRead(7);
  for(int i=0;i<6;i++){
    Serial.print(i+1);
    Serial.print(": ");
    Serial.print(analogBuf[i]);
    Serial.print("   ");
  Serial.println();
  delay(500);
Wonder what's connected to A4 and A5, if anything.
LEDs
  FastLED.addLeds<WS2811, DATA_PIN, GRB>(leds, NUM_LEDS);
IR obstacle detector
Seems to be somewhat flaky. Needs a bit more work to figure out. Also, the IR sensor might be useful to read IR remote controllers or beacons. This receiver seems to work at 38kHz, but probabbly also reacts to 36-40kHz. Remote controllers often work at 36kHz. Note that 2x 8µs delay doesn't give you 38kHz, but the digitalWrite itself also induces quite some delay (3-6µs), so seems this is bringing the total period up to around the 26.something µs we'd expect.
#define NUM_LEDS 12
// Data pin that led data will be written out over
#define DATA_PIN 13
CRGB leds[NUM_LEDS];
#define IR_IN  7//IR receiver pin
#define L_IR 8  //left ir transmitter pin
int count;
  int i;
  for(i=0;i<24;i++){
    digitalWrite(L_IR,LOW);
    delayMicroseconds(8);
    digitalWrite(L_IR,HIGH);
  int i;
  for(i=0;i<24;i++){
    digitalWrite(R_IR,LOW);
    digitalWrite(R_IR,HIGH);
    PCICR |= 1 << PCIE2;
  count++;
void obstacleAvoidance(void){
  char i;
  count=0;
   leds[5] = CRGB::Green;
   FastLED.show();
  for(i=0;i<20;i++){  //left transmitter sends 20 pulses
    leftSend38KHZ();
    delayMicroseconds(600);
    leds[5] = CRGB::White;
    FastLED.show();
    Serial.println("Left");
    delay(100);
  count=0;
  leds[3] = CRGB::Green;
  FastLED.show();
    rightSend38KHZ();
    leds[3] = CRGB::White;
    FastLED.show();
    Serial.println("Right");
    delay(100);
  delay(600);
void setup(void){
  delay(2000);
  Serial.begin(9600);
  leds[4] = CRGB::Blue;
  FastLED.show();
  delay(2000);
  leds[4] = CRGB::Purple;
  FastLED.show();
  noInterrupts();
  pcint0Init();
  interrupts();             //enable the interrupt
void loop(void){
    obstacleAvoidance();
IRreceiver
Since DFrobot also have a 'loose' IR-receiver module in their program, decided to just see if the example sketches for those would transfer, and they do. So, using the IRremote library you can read values from a remote controller:
#include "IRremote.h"
IRrecv irrecv(IR_IN);
decode_results results;
void setup(void){
  Serial.begin(9600);
  irrecv.enableIRIn(); // Start the receiver
void loop(void){
  if (irrecv.decode(&results)) {
    irrecv.resume(); // Receive the next value
This was already useful to read codes from a remote and play these back via a universal remote app on the smartphone that was missing some buttons. For some reason I couldn't find the 'learn' function in the app, but could enter the codes as read by this sketch easily.
MP3-player
There is an MP3.player integrated in the robot. It can be controlled by sending more or less magic commands over software Serial via pin 11. Pin 2 might be connected to the player too, but my tests so far never had anything received there (like an end of song reached, or even just an 'ack').
An example found on the DFRobot site:
#define MP3_VOLUME 0x10
#define TX 11
#define RX 2
#include <SoftwareSerial.h>
void setup()
  delay(1000);
  mp3Init();
  mp3setVolume(30);//0~255
void loop()
  mp3player(1);
  delay(2000);
  mp3stop();
  delay(1000);
void mp3Init()
    mySerial.begin (9600);
void mp3setVolume(byte vol)
    mySerial.write(buffer, 8);
    delay(20);
void mp3player(byte data)
    delay(20);
void mp3stop()
Eyes
Besides 35 predefined eye patterns, it is also possible to upload your own eye patterns.
#include <Wire.h>
#define I2C_WRITE   0x00
uint8_t serial=0;
void setup(){
   Wire.begin(); // join i2c bus (address optional for master)
   defined_eyes(6,1);
   delay(2000);
void loop(){
   defined_eyes(1,serial);
   serial++;
   if(serial>=35) serial=0;
   delay(250);
   Wire.beginTransmission(I2C_LED_ADDRESS << 1 | I2C_WRITE); // transmit to device #4
   Wire.write(serial);  //preset eyes 0~34
   Wire.endTransmission();    // stop transmitting
void custom_eyes(uint8_t color, uint8_t eyeline[10]){
   uint8_t index;
   // right eye         left eye
   //1  2  3  4  5      25 24 23 22 21
   //6  7  8  9  10     20 19 18 17 16
   //11 12 13 14 15     15 14 13 12 11
   //16 17 18 19 20     10 9  8  7  6
   //21 22 23 24 25     5  4  3  2  1
   Wire.write(0x55);  // color 55=custom eyes follow
   Wire.write(0xAA);  // ?? AA=color followed by 10 bytes, each defining one line
   Wire.write(color&0x7);         //color 1-B,2-G,4-R of foreground
   for (index=0;index<10;index++) {
     Wire.write(eyeline[index]);
void example_eyes() {
   Wire.write(0x1c);
   Wire.write(0x18);
   Wire.write(0x10);
   Wire.write(0x1f);  // top row all 5 bits lit
   Wire.write(0x0f);  // leds 6,7,8,9 on 10 off
   Wire.write(0x07);  // 11,12,13 on,  14,15 off
   Wire.write(0x03);
   Wire.write(0x01);
