Flashforge AD5X
Versie door Fluffyredpanda (overleg | bijdragen) op 12 jul 2026 om 21:05
(wijz) ← Oudere versie | Huidige versie (wijz) | Nieuwere versie → (wijz)
Flashforge AD5X
This page is a work in progress. Not all information may be correct yet. Please add information if you have used this 3D printer.
Slicer
OrcaSlicer: https://www.orcaslicer.com/
Flash Studio: https://www.flashforge.com/pages/flash-studio-desktop
OrcaSlicer setup
Look at this page from step 16 onward if you want to use OrcaSlicer: https://wiki.zmod.link/Setup/
Host Type: Octo/Klipper
Printer Agent: Moonraker
Hostname, IP or URL: <IP address>:7125
Device UI: <IP address>
Adding the :7125 port after the IP address is very important for this to work. On that port it will be able to recognize the Host Type. The device UI runs on port 80. So entering the IP address under Device UI will suffice.
Flash Studio instructions
1. Go to 'Device' Tab
2. Click on the '+' icon
3. Click under Other Device on AD5X
4. A popup will show. It will ask for the printer access code. This will show on the 3D printer itself under "Settings (gear icon) > Network (wifi icon) > Network Mode".
5. The FlashForge AD5X will now show up under 'Device List' in Flash Studio.
WebUI
There is a web interface (Fluidd) available on the printers IP Address:
http://<IP-Address>
For example you can upload printer files or move the printer head.
Firmware
ZMod
This is 'extra' firmware on top of the original printer. "Z-Mod doesn’t replace the stock firmware — it enhances it". Comes with Klipper updates that the original firmware does not provide. The Zmod firmware also installs Fluidd which enables a WebUI on the printers IP address.
